Ultra Miniature 3V E10 Indicator Light Bulb Needed
Home › Forums › Help and Assistance! (Offered or Wanted) › Ultra Miniature 3V E10 Indicator Light Bulb Needed
  • #370614
    Martin King 2
      @martinking2
      Hi All,
      Have tried everywhere to find one of these tiny bulbs:
      The diameter of the screw part is 5.25mm; the length of the bottom metal part is 9mm from the rim to the bottom contact; runs off 2 AA cells.
      It is for the indicator lamp on an old torque wrench tool.
      Tried RS, FARNELL etc but no go, any thoughts please?
      Cheers, Martin
      #33263
      Martin King 2
        @martinking2
        #370616
        KWIL
          @kwil
          for a start
          #370629
          pgk pgk
            @pgkpgk17461
            If really stuck for a solution then diagnostic set bulbs from the like of heine or welch allyn might be adaptable since their screw end is generally smaller than the bulb base.
            pgk
            #370630
            John Baron
              @johnbaron31275
              Hi Martin,
              That bulb sounds like the old Christmas tree light string bulb !
              Since you have the old bulb, why not just pop a LED into the old base. You might need a resistor to current limit for the LED. If I remember correctly, a Yellow LED is about 3 volts.
              #370632
              Neil A
                @neila
                You might find what you need at "Rapid Electronics", they have a fair selection.
                Just search for E10 MES lamps.
                Edited By Neil A on 06/09/2018 11:04:33
                #370644
                Grindstone Cowboy
                  @grindstonecowboy
                  I think you are looking for an E5 LES type
                  Similar to **LINK**
                  But that's a 6 volt one – it would still work though.
                  #370670
                  Martin King 2
                    @martinking2
                    Thanks very much guys, will check those out.
                    Martin
