Two cylinders steam engine.
Home › Forums › Locomotives › Two cylinders steam engine.
  • #235844
    Juan de Dios Baile Garcia
      @juandediosbailegarcia99474
      Hello,
      As gain experience with the tools and knowledge I decided to make another more powerful engine.
      This is two cylinders. They have a diameter of 20mm
      Also it built manually.
      Video 1
      Video 2
      Greetings to all
      #1518
        Two-cylinder engine built to manually
        #236185
          Hello,
          This was the boiler that did to the engine:
          Video 3
          As I was not happy I decided to build this other double body:
          Video 4
          I connected the engine to the boiler and this was the result:
          Video 5
          Greetings
          #252099
            Hi,
            With this engine I decided to make another car.
            I began by chassis and wheels that had adapted.
            Also manufactures an alcohol burner.
            With RC station I control the passage of steam.
            Video 6
            then put a servo to control the direction and also changed the ratio of the transmission and greatly improves speed (weighs 9.5kg.)
            Video 7
            Greetings.
            #252341
              Hi,
              I put the wheels were temporary. As there was a proper I decided to make some.
              I fabricated a bending sheet metal bender tires.
              Now looks better:
              In this video the construction process is as follows:
              Video 8
              greetings to all.
              #252351
              Thor 🇳🇴
                @thor
                Hi Juan,
                Nice steam engines, the new wheels look much better.
                Thor
                #252379
                  Very good Juan. Interesting steam models and with radio control too. Thanks for sharing,
                    Thanks for your comments.
                    Now I'm doing a gearbox 2 speed. I will publish progress
                  Home › Forums › Locomotives › Topics
