trimming grinding wheel
Home › Forums › Manual machine tools › trimming grinding wheel
  • #69002
    Nobby
      @nobby
      Hi Les
      Have you got a system to trim your grinding wheel on this set up.?
      On the alexzander cutter grinder there is a swing type diamond holder
      On the guard
      Regards Nobby
      #11781
      Nobby
        @nobby
        #69007
        Les Jones 1
          @lesjones1
          Hi Nobby,
          I just clamped a single point diamond dresser to the table and traversed it from side to side. This set up was just a lazy way to make grinding rest. I had the cross vice from my first attempts at milling on a drill press. (Not very successful.) The end mill grinding jig is Harold Hall’s design from issue 170 of MEW The use of a cheap bench grinder is also Harold Hall’s idea from his book “Tool and cutter sharpening” I added a key way to his design to allow me to run the grinder in either direction without the wheel nut unscrewing.
          Regards Les.
