Too cold for the machine shop
Home › Forums › The Tea Room › Too cold for the machine shop
  • #704928
    Fulmen
      @fulmen
      Today it was -5C, had to move the coolant tank as it was starting to freeze. Outside it’s a cool -17C, tomorrow they’re predicting -25. Good thing I haven’t filled the bridgeport with coolant.
      #704964
      Mark Rand
        @markrand96270
        Do you need to do some welding or blacksmith work? 🙂
        #704974
        Robin Graham
          @robingraham42208
          Cripes. I’ve been feeling sorry for myself at +10 C in the workshop. Luxury apparently!
          Robin.
          #704983
          Bill Phinn
            @billphinn90025
            I’d gladly swap you our almost incessant wind and rain for your crisp -25.
            #705007
            Ady1
              @ady1
              Dressed like a winter hillwalker I can only go to about zero degrees
              Below zero and the metal sucks too much heat out of your hands
              Goodness knows how the Russkies cope, but they do, must be tuff
              I try to do heavy electrical work when its cold, welding, milling, turning cutting
              Electrical gear likes the cold, hates the heat. Even the Royal Navys shiny new electric drive system went t**s up in the gulf and had to be redesigned
              #705037
              Fulmen
                @fulmen
                @Bill: So would I. This is over in less than a week, I can keep the shop above freezing as long as the temperature doesn’t dip too far under -10. And a 2kW heater is enough to raise the temp to 10-15C in an hour or so. I don’t need more than that as long as I’m working.
                #705051
                John Hinkley
                  @johnhinkley26699
                  I went into my garage/workshop the other day to find the temperature at 22°C, according to the 3D printer. It certainly was toasty warm, despite the outside air temperature being around 5°.  The fact that I’d accidentally left the fan heater on for 24 hours or so probably goes some way to explaining it!  I try to remember to check twice that everything is switched off now, before vacating the building.
                  And yes, the electricity bill WAS a little elevated that month!
                  Roderick Jenkins
                    @roderickjenkins93242
                    That’s where the derided (on this forum) smart monitor comes in useful.
                    Rod
                    #705060
                    Fulmen
                      @fulmen
                      I keep the machines and a 2kW heater on a breaker, as it’s not at home I don’t want to leave it powered when I’m not there. I do have a 1kW WiFi heater so I can preheat the shop and add a little bit of heat at night when power is cheap(er). But it keeps loosing its connection due to poor range so it’s not a perfect solution.
                      #705176
                      Chris Crew
                        @chriscrew66644
                        I have an old Dimplex convector heater, on it’s lowest possible setting, switched on 24/7/365. Obviously, it is not consuming power continuously as it will only kick in when the ambient temperature drops below a certain level, although I don’t really know what that is. What I do know is that the workshop temperature never drops below 8 or 9C which is comfortable to work in on the coldest evenings and keeps the rust fairy at bay.
                        During the ‘energy crisis’ I switched the heater off, fearing a large electricity bill, which seemed sensible at the time and the workshop cooled down but one day there was a sudden rise in the outside temperature. Maybe it was my mistake in opening the door but the amount of condensation on the machines was quite considerable and I spent at least three days wiping down the machines, not daring to switch anything on lest there was water in the electrics, static converters etc. until I was confident everything had dried out. Needless to say the heater was immediately switched back on, accepting that any rise in the electricity bill would be money well spent. I am in the fortunate position of being able to cover the cost but economy of energy use in other areas of the house has kept the bills almost the same as before.
                        #705498
                        Fulmen
                          @fulmen
                          Aaaand now my car battery is flat. Oh joy.
                          #705749
                          Harry Wilkes
                            @harrywilkes58467
                            My late friend worked for a UK manufacture of fire engines and on a couple of occasions he took a engine to Russia he said the demonstrations were hard work due to the water turning to slush as it left the fire hose nozzle and would eventually freeze and block the nozzle completely !
                            H
