TomSeniorMdel E S head
Home › Forums › Manual machine tools › TomSeniorMdel E S head
  • #14141
    maurice martin 1
      @mauricemartin1
      #520973
      maurice martin 1
        @mauricemartin1
        Hi Does anyone have any servicing data on this machine. Like an exploded view of the parts & assembly. Before I start taking it apart.
        M L Martin
        #520977
        davidk
          @davidk
          Hi Martin
          Are you a member if the Tom Senior group on groups.io?
          If not, it's definitely worth joining. They'll definitely have all the information you need.
          Hope this helps
          David
          #520978
          Peter Simpson 1
            @petersimpson1
            If you google Tom Senior S type head there are some Denford exploded diagrams showing most of the head. I used them when I renewed the Timken roller bearings in my S type head.
            #521075
            old mart
              @oldmart
              The spindle bearings in the S head, which is probably the same mechanically are 1" x 2" x 0.591", top and bottom. Code number 07100s/07210x taper roller. The split nut which adjusts the spindle bearings has a left hand thread.The nut is locked by a SHCS reachable through a hole near the top of the quill.
