Tom Senior M1 suds belt
Home Forums Beginners questions Tom Senior M1 suds belt
  • #334422
    Andy Carruthers
      @andycarruthers33275
      I am trying to source a Tom Senior M1 suds pump belt so far without success, can anypne point me in the right direction please?
      #9022
      Andy Carruthers
        #334425
        Senior Yates
          @senioryates
          Hi Andy,
          If you can look at old MEW there is an article on refurbishing a Tom Senior, I've got them somewhere but can't put my hands on them. If not I made one as my M1 has a spacer to give me more head room out of 10 mm rubber belt that you glue together.
          #334443
          Graham Williams 5
            @grahamwilliams5
            Note made by previous owner of my M1 in the operators manual that came with it that suds pump belt is A850 A32 PB, never had to replace mine so can't guarantee it, might be helpful.
            Cheers
            Graham W
            #334471
            Andy Carruthers
              Thank you both – appreciated!
              https://www.bearings-online.co.uk/item/1607/VeeBeltsWedgeBelts/A850–A32-V-BELT.html
              I'll see whether this fits…
              Edited By Andy Carruthers on 30/12/2017 13:54:23
              #334487
              ronan walsh
                @ronanwalsh98054
                If you wait til monday, i will pull the belt off my machine and measure it.
                #334593
                Andy Carruthers
                  Thanks Ronan, that would be very helpful
                  The one supplied when I bought the machine is unusable, red 10mm tube section 920mm long with a single joint, badly cracked – looks like an old temporary alternator belt – definately not a pair of Val's old knickers for those who remember Blue Peter
                  #335454
                  Andy Carruthers
                    Turns out this belt is too short: https://www.bearings-online.co.uk/item/1607/VeeBeltsWedgeBelts/A850–A32-V-BELT.html
                    Am awaiting delivery of the replacement
                    #335687
                    Andy Carruthers
                      Z35 Vee belt from Bearings Online – http://www.bearings-online.co.uk – £9 delivered 920mm Outside Diameter fits nicely
