Tich drawings.
Tich drawings.
Home › Forums › Drawing Errors and Corrections › Tich drawings.
  • #53321
    Eric Cox
      @ericcox50497
      Should the threads on the Pump wrist pin be 7/64″ and not 7/32″ as shown
       Is there any reason for the passageways on the pump body and bottom union to be reamed 1/8″ whilst in the top union it is drilled No.40 and what is the diameter of the horizontal passageway in the top union
       A request, can small components be drawn 2 or 3 times full size for the sake of clarity.
      #38735
      Eric Cox
        @ericcox50497
        #53438
        Eric Cox
          @ericcox50497
          Any comments.
          #53439
          jason moore 1
            @jasonmoore1
            The threads on the wrist pin should be 3/32 or 7ba the end of the pin being machined from 7/64 to suit for a length of 5/32. The passageways on the pump body and the bottom union are reamed 1/8 to provide a seating for the pump balls. Note that while the bottom union can be faced off to provide a flat seating the 1/4 x 40 top hole on the pump body needs to be drilled 7/32 and then a flat bottom formed in the hole with the same sized D bit before tapping,being careful not to damage the seat with the tap. The horizontal passageway in the top union is No.40.
            #53440
            jason moore 1
              @jasonmoore1
              One thing i forgot to say.The drawings also show the small end of the pump eccentric rod drilled 3/32,this is a mistake which should read 7/64 to match the diameter of the wrist pin.
