Threads on milling cutters
Home › Forums › Workshop Tools and Tooling › Threads on milling cutters
  • #20053
    Martin Dowing
      @martindowing58466
      #511597
      Martin Dowing
        @martindowing58466
        Some milling cutters have thread on their shanks which is meant for special holder.
        I need to extend such 6mm cutter to make 5 inch long mill suitable for drilling screw socket in awkward place.
        Its threaded part of shank has diameter 5.65mm and the thread is 20 TPI,
        So it is not a standard thread I am used to.
        I want to drill and thread extension bar and then drill again and ream to 6mm, so only bottom of hole is threaded. This should prevent mill rotation during drilling this socket.
        Which tap is best to use?
        Will 1/4" Whitworth 55*/20TPI tap do or are there some special taps for this purpose?
        #511599
          Specials as far as I know. The older 1/4 x 20 Whit of imperial cutters as carried over to metric but they only kept the pitch so your thread is M6 x 20tpi or M6 x 1.27 in new money
          Probably easier to get a 6mm FC-3 cutter and make a simple extension that has a grub screw to bear on the flat.
          Or if "screw sockets" are counterbores for cap heads then a piloted counterbore would be the best bet as an extended milling cutter may jump about a bit..
          #511601
          Anonymous
            The threads on cutters intended for Clarkson style holders are Whitworth form and 20 tpi, irrespective of whether the cutter is imperial or metric. I was under the impression that the shanks of such cutters were of a limited range of sizes. My smallest holders are 1/4" and 6mm and have 1/4" and 6mm by 20 tpi threads respectively.
            I'm not aware of special taps for any of these threads (other than 1/4" BSW) and 5.65mm seems non-standard. Not much help I'm afraid. sad
            #511603
            IanT
              @iant
              Would an ER11 or ER16 straight shank collet chuck fit into the available space Martin?
              I have ER16 collet shanks (that I hold in an ER32 chuck) that can be used to provide extra reach when required.
              IanT
              #511605
              Martin Dowing
                @martindowing58466
                Posted by JasonB on 04/12/2020 13:06:07:
                The extension bar has to be of 8mm diameter due to particular awkwardness of place to be drilled, so the grub screw is out of question. It will be made out of 8mm h6 bar for linear bearings, hardened to depth about 0.7mm.
                Regarding counterbore – have to find if suitable size (4/6mm) is available.
                Another idea – just make a reamed hole 6mm @ h6 and glue in shank of the mill with metal retainer.
                Apply coolant during milling.
                Edited By Martin Dowing on 04/12/2020 13:37:57
                #511607
                DC31k
                  @dc31k
                  Drill extension bar 6mm. Loctite. Let it cure. Use it.
                  #511608
                  John Haine
                    @johnhaine32865
                    Just drill and if possible ream the extension for a close fit on the shank and then use Loctite to fix it. If you need to get it apart just boil hard in water for a few minutes, of gently heat with a blowtorch.
                    As Jason implies, good luck trying to drill a counterbore with an unsupported milling cutter.
                    #511610
                    Martin Dowing
                      @martindowing58466
                      @DC31k & John Haine,
                      Thanks,
                      Just got the same idea while you was writing your posts.
                      Hence my edit above.
                      It should work.
                      I can just start initial 1mm with 6mm drill, then finish job with a mill.
                      #511615
                      Rob McSweeney
                        @robmcsweeney81205
                        Some of the older textbooks describe grinding a drill bit with a flat end as a "bottoming drill".
                        Could be worth trying with a long series drill, unless you need carbide for the metal you are working with.
                        #511617
                        Martin Dowing
                          @martindowing58466
                          Posted by Rob McSweeney on 04/12/2020 14:10:30:
                          45HRc, so HSS-Co coated with TiCN will do. Normal HSS also works but getting blunt fast.
                          Don't want to extend carbide mill as some loss of rigidity may result in damaging it.
                          #511618
                          John Haine
                            @johnhaine32865
                            If you are counterboring, it doesn't have to be flat bottomed, you could just use an ordinary drill?
                            #511619
                            Martin Dowing
                              @martindowing58466
                              Posted by John Haine on 04/12/2020 14:18:08:
                              If worst come to worst I may have to settle with that.
                              #511621
                              old mart
                                @oldmart
                                Although the thread pitch on all the threaded cutters is 20tpi, the size of the thread is the cutter shank size. That 6mm cutter will have a 6mm X 20tpi thread. I very much doubt if the taps would be available easily. All of the threaded shank cutters up to 16mm have the 20tpi thread, I cannot say whether the larger ones have the same pitch as I do not have any to check.
                                I would Loctite the 6mm into an extention to do the milling. Make the extention as large diameter as possible for stiffness and take light cuts.
                                #511624
                                Martin Dowing
                                  @martindowing58466
                                  @old mart,
                                  Mill shank is 6mm but threaded part is 5.65mm @ 20 TPI
                                  Have been measured.
                                  It will be used for counterboring, not for regular milling.
                                  #511627
                                  Anonymous
                                    Posted by old mart on 04/12/2020 14:50:06:
                                    …….I cannot say whether the larger ones have the same pitch as I do not have any to check.
                                    Yes, they are. I've just double checked 25mm/1" to 50mm cutters and they're all 20 tpi Whitworth.
                                    #511628
                                    Tony Pratt 1
                                      @tonypratt1
                                      Posted by Martin Dowing on 04/12/2020 14:54:44:
                                      @old mart,
                                      Have been measured.
                                      So well undersized 6 mm?
                                      Tony
                                      #511630
                                        Just measured a 6mm shank Dormer and that's a similar 5.65mm over the crests of the threads.
                                        1/4" shank Dormer is also well under at 0.236" over the threads
                                        I see that the likes of Tracy do M6 x 1.25mm taps which would be close to the1.27mm cutter pitch and if as slack as they measure the difference in angles may not be a problem over a short length of thread
                                        #511634
                                        old mart
                                          @oldmart
                                          Measuring threads usually gives smaller than nominal results.
                                          #511642
                                          DC31k
                                            @dc31k
                                            It is worth reading the datasheet for the proposed 'glue' before you begin.
                                            To work best, it needs some clearance and surface roughness to give a film thickness and a good bond. Hence a reamed hole might not be the best and a rub of the cutter shank with a coarse diamond stone will not harm anything.
                                            #511644
                                            Phil P
                                              @philp
                                              Why not use a long series drill for most of the hole depth, then finish it with a D bit which can easily be made.
                                              Phil
                                              #511657
                                              Martin Dowing
                                                @martindowing58466
                                                Posted by Phil P on 04/12/2020 16:06:52:
                                                Phil
                                                Chinese are selling 6 mm carbide mills with 150 mm long shank rated for 45HRc for 12 queeds including p&p so they are essentially given for free.
                                                Easy enough to order via Aliexpress.
                                                But you have to wait 2-3 weeks before one arrives.
                                                #512685
                                                Martin Dowing
                                                  @martindowing58466
                                                  Hi,
                                                  So I have done these counterbores for screws.
                                                  130 mm long 8mm diameter surface hardened bar was drilled & reamed to H7 tolerance, 6mm Chinese solid carbide mill was glued in with Loctite 638.
                                                  Next day it was fitted in the collet and counterbore drilled directly in my part (45 HRC).
                                                  There was already predrilled 4mm hole there and center was fould with aid of straight and ground 4mm bar in usual way.
                                                  Mill was not tending to wander much so only slight taper resulted (6.2mm on the top and 6.1mm on the bottom of counterbore.
                                                  But for this application it is OK.
                                                  #512716
                                                  old mart
                                                    @oldmart
                                                    For tight tolerances, it is useful to know that a slot drill, or endmill will not produce a perfectly square counterbore. This is because the end cutting edges are not square to the tools axis. The counterbore will be slightly deeper at the outer diameter than the inner. This probably does not matter if a screw is to be fitted in the counterbore.
