thread of a record 36 vice
Home › Forums › Manual machine tools › thread of a record 36 vice
Viewing 23 posts - 1 through 23 (of 23 total)
  • #12206
    Ian Welford
      @ianwelford58739
      #133689
      Ian Welford
        @ianwelford58739
        Anyone know the thread of the screws which secure the jaw plates on a record 30 quick release vice? They heave quite a fine thread ( I['m guessing imperial?) and a taper to the screw head. Slots on mine are a bit knackered (not me got it 2 years ago) and I want to replace the jaws with aluminium so might as well fit new screws at the same time.
        Cheers Ian
        #133690
        Ian Welford
          @ianwelford58739
          OOps- typo- Record 36 vice!!!
          #133703
          Gone Away
            @goneaway
            Why replace the jaws? You can get a whole new vice here for only £821 crook
            #133720
            Brian Wood
              @brianwood45127
              Hello Ian,
              I've checked my 4 inch Record, those jaw screws are 1/4 inch Whitworth 20tpi with 3/4 inch of thread under the countersunk head. I would imagine the makers standardised on that size for the whole range of vice sizes, why do otherwise?
              As for podding out £800+ on a new vice, surely a joke!!
              Regards Brian
              #133724
              Ady1
                @ady1
                It's probbly a solid steel unit
                #133743
                Gone Away
                  @goneaway
                  Posted by Brian Wood on 26/10/2013 10:04:23:
                  Certainly in my case (hence the smiley). I believe the seller is serious though.
                  #133765
                  Stovepipe
                    @stovepipe
                    Sorry, which planet did you say they were on? But I expect solid gold is cheaper there.
                    Dennis
                    #133768
                    The Merry Miller
                      @themerrymiller
                      What you may not have realised is that delivery is free, normally it would be about £700 or there about.disgust
                      Len. P.
                      #133779
                      Stovepipe
                        @stovepipe
                        Have they taken "Record" in the name too literally ?
                        Dennis
                        #133782
                        Keith Long
                          @keithlong89920
                          The T36 isn't even the expensive one – the T114 comes in at over £1000 +vat
                          Keith
                          #133900
                          Ian Welford
                            @ianwelford58739
                            Hi Brian
                            Sadly they may have standardised NOW but the ones in this one are 1" long, 26 tpi and almost a square form thread (?) with a large degree of taker under the head for the first 1/4". The diameter ( to top of thread) is 302 thou.
                            BSF perhaps?
                            I should add they were certainly put in never to be removed without considerable effort ! Mine have now been extracted, copper slipped and reinserted.
                            Until I extracted them and compared to the ones shown as a spare available now, I was going to bite the bullet and order a set of jaws etc ( £50 !!!) but they're totally different.
                            I have e mailed record to see what their view is and will update this when I know.
                            Made me feel a bit better when I saw the same vice on ebay for £170! Mind you you have to go and collect it. Just about gave me a hernia when I picked mine up !
                            Thanks one and all
                            Ian
                            #134613
                            Ian Welford
                              @ianwelford58739
                              The threads are apparently 312 thou diameter, 26 TPI BSW free fitting! So cays the IRWIN tools technical helpline!
                              Now I've just got to source some. Or make some perhaps and case hardenindecision
                              Regards Ian
                              #134659
                              Ian S C
                                @iansc
                                .312 = 5/16", 26 TPI is 5/16" UNF, not BSF which is 22TPI, Whitworth is18 TPI, so I don't know what Irwin Tools are talking about, or maybe they don't.
                                Ian, your 1/4 x 26TPI screws are BSF.      Ian S C
                                Edited By Ian S C on 05/11/2013 13:21:53
                                #134684
                                Springbok
                                  @springbok
                                  To this company there was a person on a tennis court who used to to say "You have to be joking"
                                  Bob
                                  #134686
                                  Springbok
                                    @springbok
                                    Got one of these years ago when ELF and SAFETY decided to have our metal working shop shut down, if I remember it originally cost around 15.00. another thing was a very large anvil on a stand a few years before this they decided to instruct us that the point must be removed as a student might impail themself. (God there were a few that I would have happily stuck them on backwards) now back to the plot will take mine apart and measure it.
                                    Bob
                                    #134690
                                    John C
                                      @johnc47954
                                      I have a record No 5 vice of some considerable vintage. The screws that hold the jaws are 5/16 BSW by 1 inch total length, countersunk.
                                      I got my replacements from EmKay Screw Supplies (WWW.emkaysupplies.co.uk) at a very reasonable cost and quick delivery. I bought the 1 1/4 long screws and cut them down.
                                      Rgds,
                                      Barry Doolan
                                        @barrydoolan76365
                                        I know this is an old thread but just wanted to add the following info in case anyone is searching in the future.
                                        I have two record 36's at the moment and the older one with 'steel' on the side has a 5/16 BSW 18 TPI thread holding the vice jaws on. The newer one seems to use something like and 8mm x 1mm pitch thread, it certainly isn't a 24tpi or 26 tpi thread, I've checked against the old screw and the replacement sent with the new jaws I have bought.
                                        #178443
                                        Nicholas Farr
                                          @nicholasfarr14254
                                          Hi, as far as price go's for a new T36 Record vice, it is no joke. These are designed for industrial use and incorporates an anvil. plus quick release. Both Cromwell Tools and Buck and Hickman have as similar price to the one linked in the above post. See **LINK** and **LINK**
                                          Regards Nick.
                                          #178468
                                          Brian Rice 1
                                            @brianrice1
                                            Good heavens I gave one away about ten years agocrying 2
                                            #178785
                                            Trevor Drabble 1
                                              @trevordrabble1
                                              Ian,
                                              I have an original Sheffield made Record 25 vice in excellent condition which I am about to advertise . You're welcome to first refusal if you feel you can lift it ! Pictures can be supplied . I am in South Yorkshire.
                                              Trevor.
                                              #178792
                                              Harry Wilkes
                                                @harrywilkes58467
                                                You find a lot of inflated prices on ebay it's done to avoid fee's when the item is not in stock !
                                                H
                                                like this
                                                Edited By Harry Wilkes on 07/02/2015 06:20:10
                                                #179274
                                                charadam
                                                  @charadam
                                                  What!
                                                  You mean I could have bought them cheaper?
