Is this your Drummond? If so check the pitch of your leadscrew as that is a very unusual pitch, it is more likely to be moving 9.53mm in three turns eg 8tpi leadscrew.
You will need some way to syncronise the feed motor with the spindle as if the lateh slows during the cut you will need the motor to do so too.
There are several long threads here, have a search for "electronic leadscrew" Try this one for starters
Edited By JasonB on 13/05/2017 13:32:13
