This or That
This or That
Home › Forums › Beginners questions › This or That
  • #323068
    Harry Wilkes
      @harrywilkes58467
      HI have been thinking of getting s small mill firstly I have very little room and secondly mainly only need it to maintain my 3" Burrell. I have considered the Sieg SX1L however I was at the midland Model Exb the weekend and saw the Chester conquest Super Mill. I would welcome comments about these machine and do any forum members use these mills ?
      Thanks
      H
      #8924
      Harry Wilkes
        @harrywilkes58467
        #323074
        nigel jones 5
          @nigeljones5
          Hi Harry
          I have owned both of these, indeed still got the Chester, now heavily modified to suit its application. If you have the space and money go for the bigger machine, it is superior in every way.
          #323084
          Russell Eberhardt
            @russelleberhardt48058
            A problem with these little mills is that the tilting column is far from rigid. If you can fit the slightly bigger SX2P in I would recommend it. I have found it to be a very capable little mill and much more rigid.
            Russell
            #323126
            nigel jones 5
              @nigeljones5
              The tilting column is indeed a weak spot – found out the hard way after drilling 6 loco wheels only to find every one was out by a mile – always tram the head before critical job..lesson learnt.
              #323172
              John Reese
                @johnreese12848
                I would suggest buying the largest mill your space and wallet can accommodate. The difference in rigidity between small mills and larger machines. is amazing. If your projects will include a lot of boring I suggest looking for a machine with power feed on the quill. I have owned a round column mill-drill, a Rong Fu RF45, and a full sized Bridgeport clone so I can speak from experience.. Another thing to consider is the size of work you will be doing. You can do small work on a larger machine, but not vice versa. If you have a choice between a Morse taper spindle and R8, I suggest R8.
