Hi All
For a long time I had a very early (Pre war) flat belt driven Colchester with change gears. I fitted it with a DC motor and speed control not a modern VFD. The variable speed allowed me to screw cut up to a shoulder with relative ease. The DC Drive was an enormous help. That together wit a quick flick of the cross slide handle and I was able to job the job with little effort.
My current lathe is a German VDF Heidenreich and Harbeck RO 80 it does not have a VFD and the headstock is driven directly with no belts. It does however have slow speeds down to 25rpm. This lathe is about 25 years old.
A feature that is extremely useful is the wet multi plate clutch(s) and a reversing gear set that are engaged by the forward and reverse lever. This gives the same functionality as a clutch driven car. The main motor runs continuously when the machine is turned on. you can throw the leaver for an abrupt start or reverse or ease it in. I am assuming here that common sense will prevail and that a Machinist would not deliberately slam the lathe into reverse at high speeds. I am sure it can take it but I do not intend to try it. This machine has a DIN taper spindle with 4 bolts so there is no risk of the chuck coming off a thread. from the inertia of reversing. Threaded spindles should be a thing of the past.
The apron hand drive handle also has a movable graduated dial. Having set the cross slide dial to zero at the start of the cut and the saddle hand wheel dial to the stopping point. I am ready to cut the thread. So I engage a low gear, have one hand on the reversing lever one hand on the cross slide handle, make the first cut until the saddle hand wheel reaches the zero point, at which point I flick the cross slide handle to withdraw the tool and throw the clutch to reverse the machine. I mostly cut metric threads and so I usually leave the half nuts engaged unless it is a long thread.
I think an ideal lathe should have this setup if mechanical. Or a VFD that is capable of slow speeds (Not all are), without having to shift belts, a soft start and the ability to reverse while running with ramp up and ramp down so the machine is not subjected to stress.
Also a large graduated apron feed dial is a must.
If any member has a similar machine please IM me it would be good to compare notes.
Cheers
Edited By John McNamara on 28/09/2011 14:26:09
