Tertium Quid Drawing Errors
Home › Forums › Drawing Errors and Corrections › Tertium Quid Drawing Errors
  • #38730
        Just spotted a few errors on these drawings
        Base plate (both drawings) the overall size of the cut out is given as 1/4″ (25mm) assume it should be 1″.
        Also on the base plate there is no way of locating the cutout vertically. I think it should align with teh 1/8 & 1/4 hole positions abu as drawn the cutout lines do not line up with the centre holes.
        Flywheel The side elevation gives a total rim thickness of 1/4″ but the section gives 1/4 + 1/16
        Don’t know if the metric dims are a new addition or from the original article but if newly added can they be consistant. 1 1/4″ is shown as both 30mm and 32mm. 7/8″ is given as 24mm and 25mm when its usual to round it to 22mm
        I’ll let you know if I see any more
        #48466
        David Clark 13
          @davidclark13
          Hi There
          I just posted the drawing as is.
          It was drawn about 20 years ago.
          I will update when I get time.
          regards David
          #48503
          Terryd
            @terryd72465
            There also appears to be a mistake on he positioning of the holes for the side brackets of the main body.  Th one on the RH side of the cutout is marked as being 15/32 (12) and it appears way out of alignment with a lower hole for the pillar which is marked as 1/2 (12).
            I know as an ex engineer not to, scale drawings but this looks wrong especially as the corresponding left hand hole is marked as being 21/32 (16) from centre which makes it only 11/32 in from the edge,  which I suspect, is the correct dimension in for the right hand hole and not the 15/32 shown.
            #48504
            Terryd
              @terryd72465
              By the way, there are two copies of the Terium Quid baseplate drawing in the ‘Best Of Model Engineer Vol 2’. one on page 21 and one on page 23.
              Is this significant?
              #48519
                Valve nut is also given as 4/32 (7) should be 9/32
                J
                #48663
                Sub Mandrel
                  @submandrel
                  I’ve been trying to find the Stan Bray articles on the site and can’t.
                  Could you point me at Tertium Quid and Lusus Naturae please?
                  TIA
                    They are in the “Best of Model engineering Vol II” don’t think its on the site.
                    Jason
                    #48675
                    David Clark 13
                      @davidclark13
                      Hi There
                      Yes, in the best of.
                      A couple of minor corrections are on the site.
                      regards david
                      #48734
                      Sub Mandrel
                        @submandrel
                        Have to go shopping then!
