As Stew uses metric sizes you will have to get metric rings to suit, I have used these people a few times who have a good range of the Vitron ones.
You can also fill the ring groove with Graphite or PTFE inpregnated yarn which is less critical on the correct groove size. This can also be used as gland packing.
If you are just running for display then you should be able to get away with no rings if fit and finish is reasonable, this will also have less sticktion so better for slow running.
Edited By JasonB on 26/12/2017 07:08:18
