Posted by Ady1 on 10/03/2021 09:18:35:
I recall reading that really fine workers always used solid bearings because rollers caused vibration
Certainly true in the good old days because it's much harder to make roller bearings than plain bearings. Balls and rollers were especially challenging because roller bearings run rough and wear quickly if only one of them is slightly out.
Ball-bearings were popularised by push-bikes because plain bearings exhaust the rider, but early attempts to make them were only moderately successful in that they soon wore and became bumpy. The best early bearings weren't good enough for a lathe – they didn't last long enough before vibration set in.
In the lathe 19th and early 20th centuries many companies tried to find ways to mass-produce high-tolerance rolling parts and failed! During WW2 both the UK and Nazi Germany imported top-end bearings from Sweden because SKF was one of the very few makers in the world capable of producing really good rolling bearings. (Better than anything UK, Germany, Japan, France, Italy or the USA could do, even though all these countries were all in the race, ho ho, geddit.)
But this was in the long gone world of Trade Secrets, active patents, and semi-understood engineering. 80 years later it's not rocket-science to mass-produce good bearings anywhere in the world. Whilst the best bearings are still premium products, it's because of the extra care, exotic materials, and quality control typical of aerospace and other hi-tech requirements, not because there's any magic in it!
Although plain bearings are the easiest and cheapest way of making a precision smooth running lathe spindle there are disadvantages:
- Essential to keep them well-lubricated. Gravity is good enough for small tools but big ones need pressured oil systems, which cost money to maintain especially if the machine runs continually.
- Plain bearings waste a lot of energy stopping and starting. Doesn't matter in a home or jobbing workshop, but it does in a factory full of big machines restarting around the clock, year after year. While the operator might be completely happy with the machine, the accountant will periodically do the sums to see if it's worth replacing it with something more efficient. This causes consternation on the shop-floor when fine machines are suddenly scrapped despite being good for another 50 years work! Many engineering businesses went bust because the accountant was sent for far too late, or his bad-news advice was ignored.
As always, horses for courses, but today 'good enough' roller bearings are usually the best bet for most purposes, even lathes! Low maintenance, high-reliability, and standardisation means they're relatively cheap and easy to replace. Probably best not to 'save money' by rushing to nastyRubbish.com and buying the cheapest possible bearing you can find on the market though! Very cheap goods are rarely top-quality…
Edited By SillyOldDuffer on 10/03/2021 11:31:51
