Simple method would be to turn your taper on a piece of silver steel and then mill away half the diameter and then harden & temper. This method is often used for cutting tapers in steam fittings though you will get some tearing in wood depending on grain direction. Could be cleaned up with abrasive paper wrapped around a similar tapered plug.
