SX1 Mill Motor Shaft
Home Forums Manual machine tools SX1 Mill Motor Shaft
  • #13973
    Nick Clarke 3
      @nickclarke3
      Nick Clarke 3
        @nickclarke3
        I have seen many comments on the internet regarding the gears in a Sieg SX1 mill stripping gears.
        I know they are readily available from suppliers, but I am looking at the opeion of converting to belt drive, should I need to.
        So, no urgency as for a small machine it still amazes me by what it can do, but because I would like to have a design schemed out should I need it, Does anyone know the diameter of the shaft on the motor?
        I accept I could take it to pieces, but I am loathe to do so, while it is working so well. (If you suggest it is idleness you know me far too well!)
        Hopefully honesty and my self awareness may overcome people's opinions of my downright cheek!
        If you can help, Thanks,
        Nick
        #484638
          You don't need to look far
          #484641
          Nick Clarke 3
            @nickclarke3
            As I did not think knowing the size of the shaft would be necessary when ordering a spare part I did not even consider that it might be listed in the description on the ARC website.
            So thank you Jason – problem solved (and also thank you to Ketan for putting unnecessary, but highly useful information on the company website)
            Thanks
            #484644
            James Dickie
              @jamesdickie20444
              If you would like an easy route to a belt drive conversion, then I can highly recommend this one:
              The one I purchased was delivered very quickly, the parts are very well made, fit perfectly to the machine and everything works very well. Having a push button lock for the spindle makes life much easier too. The only tricky bit is building a new box for the control board, but you'll have to figure that out anyway if you do your own thing.
              I've no connection with the supplier of this kit, just a satisfied customer.
              #484649
              Nick Clarke 3
                @nickclarke3
                Posted by James Dickie on 08/07/2020 21:02:18:
                Thanks, useful
                Nick
                #484650
                Nick Clarke 3
                  @nickclarke3
                  Thanks, useful
                  Nick
                  #484664
                  Michael Cox 1
                    @michaelcox1
                    I did my own belt drive conversion, see:
                    I hope this helps.
                    #484669
                    Danny M2Z
                      @dannym2z
                      That's quite a useful linky as they also offer conversion kits for other mills (such as my X2).
                      Thank's for that.
                      * Danny M *
