Sweet William
Sweet William
Home › Forums › Locomotives › Sweet William
  • #343185
    James Roberts 4
      @jamesroberts4
      I was looking at building a Holmside but I also like the Sweet William. I understand they have a marine style steel boiler. What are these like to build and in use compared to a copper loco one. I would guess not as efficient at producing steam. What kind of load could it pull? As I’m after something that could pull me, the wife and the 2 young children. Ideally without stopping the engine after every circuit to recover.
      Thanks.
      #1682
      James Roberts 4
        @jamesroberts4
        #343206
        duncan webster 1
          @duncanwebster1
          using steel instead of copper makes practically no difference to heat transfer or steam raising, the resistance is getting the heat from the flue gas to the metal, everything else is insignificant
          #343208
          James Roberts 4
            @jamesroberts4
            But there must be a difference between the 2 designs one being marine and the other a proper loco boiler?
            Wouldn’t the steel one be more susceptible to internal corrosion?
            #343210
            FMES
              @fmes
              Hi James,
              As a 7 1/4 gauge loco you won't really have a problem with it pulling, my 5" Sweet pea will happily tow three truck loads of kids both big and small, best record was 18 on a flat track, different kettle of fish stopping it.
              All of the marine boilers are relatively easy to construct, and steel boilers steam just as well as copper in the bigger sizes, of course you do have to look after them more.
              All the best with your project
              Lofty
              #343212
              Bazyle
                @bazyle
                 They can easily pull your family and dog too.
                Edited By Bazyle on 25/02/2018 20:29:19
                #343220
                duncan webster 1
                  @duncanwebster1
                  Posted by James Roberts 4 on 25/02/2018 20:20:47:
                  Wouldn't the steel one be more susceptible to internal corrosion?
                  I make no comment on the merits of marine vs loco firebox, only on steel vs copper in otherwise same design
                  #343882
                  James Roberts 4
                    @jamesroberts4
                    Has anyone fitted a steam dome to one to get a little more steam space and a drier spot to collect the steam from. Is that even possible with a steel marine boiler?
                    #343888
                    FMES
                      @fmes
                      Never found a need personally, and you would be altering the original design of the boiler which is often frowned upon by the Boiler Inspectors.
                      Lofty
                      #343889
                      Billy Bean
                        @billybean67480
                        Posted by FMES on 01/03/2018 20:26:35:
                        Lofty
                        Still learning so excuse the question but Lofty has already stated it works perfectly as it is.
                        So James why would you want to alter a proven design?
                        #343901
                        James Roberts 4
                          @jamesroberts4
                          Just for more steam space to make it harder to run out and to provide dryer steam as it would be removed further from the water.
                        Home › Forums › Locomotives › Topics
