Sweet William
Sweet William
Home › Forums › Locomotives › Sweet William
  • #628001
    D.A.Godley
      @d-a-godley
      Could I ask ; has anyone built a Sweet William fired by gas ?
      #2175
      D.A.Godley
        @d-a-godley
        #628056
        Baz
          @baz89810
          Cannot remember it being done on a Sweet William or Pea but have seen a Simplex converted.
          #628191
          D.A.Godley
            @d-a-godley
            Baz ,
            I. see Mr Factotum is overhauling a gas firing arrangement for a Sweet Pea , so I guess it’s not unusual, but I have no idea how the upscaling will effect its performance in regard to Sweet William.
            In an effort to bring on youngsters and those with no exposure to the engineering workshop , we at Wolverhampton, are commencing the build of a Sweet William 0-6-0 Locomotive, giving them the hands on and mentored experience.
            As a charity , it’s part of our constitution to do so , and it was thought this Loco would give the chance to encounter most of the lessons needed for those wishing to develop.
            The suggested use of gas to fire the loco has been made , hence my enquiry , to see if I could gain from others knowledge, MEW , may be the wrong forum to make these enquires, sadly I don’t have access elsewhere , but thank you for responding.
            David
            #628214
            Baz
              @baz89810
              David the way coal supply is going we may all be looking at gas firing in the future. I would imagine that a Sweet Pea / William would be a much easier conversion than a conventional loco firebox as there no obstructions, axles etc in the way, something as crude as a Sievert burner mounted on Sweet Williams firebox closure plate may do the job. I am amazed that nobody else has replied so far.
              #628232
              Bazyle
                @bazyle
                If you can reach out to California I recall on a visit to LALS (Los Angeles Live Steamers) all their locos were gas fired owing to the extreme fire risk.
                A great bunch by the way, on the other side of the hill from the famous Hollywood sign, near the zoo.
                #628514
                D.A.Godley
                  @d-a-godley
                  Posted by Bazyle on 08/01/2023 18:49:36:
                  Bazyle ,
                  Thank you for your suggestion , I have emailed them and eagerly await a reply .
                  David
                  #630863
                  D.A.Godley
                    @d-a-godley
                    Somewhat disappointed in our Model Engineering brothers from USA, I have not had so much as a “ we have got your message “. And it was on their website ? , I did think talking was one of their strongpoints , and before asking , I visited it again after about a week of no response from the first occasion, guess what , no response this time either? .
                    #630873
                    Jeff Dayman
                      @jeffdayman43397
                      No idea why LALS or IBLS have not responded. Could just be no one has been checking their email portals recently. At some clubs in the US there is no one there, or very few people there, mid week. Busier at the weekends, generally, I understand.
                      In any case, at one time a few years ago many people at LALS were using a burner setup by Marty Siegel, called the "Marty burner". (no idea where they get these cryptic names.) They do work well, I have used them in several projects and they do throw some heat. Very simple to make. A link is below to the IBLS page on these, just FYI. Note that as with any gas burner in an enclosed space they are very sensitive to draft and a heavy exhaust blast at the chimney will pull the fire off the burners. If planning a gas fire I suggest making the blast pipe easily removeable or easy to modify, in case you need much less or a little more blast.
                      http://ibls.org/mediawiki/index.php/Marty_Burners
                      #630874
                      Jeff Dayman
                        @jeffdayman43397
                        A further thought – J E Nystrom in Finland has built several gas fired steam locomotives and has developed a few types of burner for use in them. Might be wise to have a look at his web pages and maybe email him for practical advice. Jan-Eric is a great guy and if he tries an approach an it does not work out – he's honest about it, and tells us about it! Just as important to know what doesn't work as it is to know what does.
                        http://sparetimelabs.com/animato/animato/steam/index.html
                        #630886
                        D.A.Godley
                          @d-a-godley
                          Jeff ;
                          Many thanks for your input , it sounds most interesting and I shall certainly follow up both of your suggestions.
                          David
                          #630891
                          noel shelley
                            @noelshelley55608
                            I had often thought of making a gas burner based on the burner panel from one of the old super ser 3 panel room heaters. The ceramic panel could be cut to size and sealed in it's box with air setting fire cement and then experiments to get the gas and air flow, both primary and secondary (top ) right. Just a thought. Noel..
                            #630949
                            duncan webster 1
                              @duncanwebster1
                              David, check your inbox.
                              The average radiant gas fire has a radiant area about 8" * 12", 96 sq in. Even a big 5" gauge loco has only 35 sqin or so. Gas fire produces 4 or 5 kW, coal fire in loco will produce 25 kW or so when working hard. It's not straightforward to burn gas in a loco firebox and get the same output.
                              Edited By duncan webster on 25/01/2023 18:34:55
                              #630956
                              Rick Hann
                                @rickhann79631
                                David,
                                I think it would be possible for you to fire your sweet William with propane. I don't know what scale you are working with, but I successfully fired a 3-1/2" Gauge Rob Roy with propane ceramic burner (firebox approximately 3"x2&quot. Burner output approximately 18,000 BTU. There is a lot of information on gas firing, but you have to look for it. If you want to see it running, just google Utube (Rick's Rob Roy). With a small firebox, it is a bit like trying to put 10# in a 5# sack. Good Luck! Rick
                                #630968
                                D.A.Godley
                                  @d-a-godley
                                  Duncan , have responded to your message, many thanks .
                                  Rick , kind of you to join in with your experience.
                                  Some useful pointers have been given by other responders, which will give me leads to chase up , the Marty Burners in particular since drawings are to hand , and I shall definitely watch the Rob Roy on YouTube .
                                  Sweet William is 71/4” by the way .
                                  Best wishes
                                  David
                                  #630976
                                  duncan webster 1
                                    @duncanwebster1
                                    Posted by Baz on 07/01/2023 18:00:26:
                                    Bit of a long shot, but do you have any details, or any link to its owner? Firebox on one of my locos is just a bit bigger than simplex,so could save me some hair tearing
                                    #630984
                                    phillip gardiner
                                      @phillipgardiner
                                      i run Martys burners in my shay the firebox is about 200mm x 125 i have made and fitted eight burners that run on two pound pressure never run out of steam and never have to clean the tubes. i live near newcastle in australia and cannot get decent burning coal.
                                      #630993
                                      D.A.Godley
                                        @d-a-godley
                                        Phillip , thank you for joining in on this topic , and the personal experience and knowledge you have .
                                        Do you run your loco at a track where members of the public attend or is it members only ? , what are the Insurance implications ? , is it cost effective , though if you can’t get coal , I guess that’s a stupid question .
                                        There are many more questions I would like to ask , if you have no objections.
                                        David .
                                        #631113
                                        Rick Hann
                                          @rickhann79631
                                          David, It seems that your best option for propane firing is the Marty Burner. You do need a large enough firebox to be able to install the burners without too much flame overlap. If you are so inclined to play around with Btu outputs versus orifice size, gas pressure and other variables, I found the following site to be helpful. Rick
                                          ronreil.abana/BTU-Caculator.xls
                                          #631127
                                          D.A.Godley
                                            @d-a-godley
                                            Rick,
                                            I have , just now , watched your YouTube posting , the running of your Rob Roy , it certainly seems to perform well .
                                            It would be very useful for me to get some information from you regarding the plumbing, what safety features , etc you have employed ? . Many in my club , I think , regard this method as the Black Arts , fearing all sorts of disasters, but I am sure that managed properly , with sensible precautions, it’s as safe as any method .
                                            If it’s not too much of an imposition, could you email me the features you built into your system , Bottle to Burner ? , I would very much appreciate that .
                                            David
                                          Home › Forums › Locomotives › Topics
