Evening all,
I have a 540 surface grinder, and to help keep the dust down, and give better finish I run a coolant hose on it. I guess it's a flood system, although I have to be careful not to open it fully as it pumps faster than the table drains…. Then it would be a proper flood.
Anyway I currently have the linelok aimed roughly at the grind zone from the back of the wheel – so the coolant is flowing in the same direction as the wheel is running.
This seems to work ok,but i wondered tonight as i was grinding an old crankshaft of i should really aim the coolant against the rotation?
Any comments?
