Just tested my 3D printed prototype, everything plastic apart from the drive shaft. Got it to around 50,000 rpm at 5psi, quite amazing when the impeller is 86mm in diameter, it is printed from polycarbonate however, just got to do a little rework on the design, then if it works I've got to completely re-print it from a higher temperature plastic (main housing is PETG) before I can give it a test in a car, hoping for around 8psi. I will scrap this design eventually and work on the gearing idea.
Posted by Joe Page on 18/10/2017 21:06:00:
I will probably knock something up of the 3D printer, if it works then I'll go to metal, of course I won't take it up to full speed in plastic.
Posted by duncan webster on 18/10/2017 22:13:53:
If you're running a 3D printed impeller at 150,000 rpm let me know and I'll keep well away from your part of the country on that day. Make sure you spin test it surrounded by sand bags. If it breaks up it will be spectacular. Why not pinch the impeller out of a turbocharger?
Hi, Duncan, I will be scavenging a compressor wheel from a turbo, spinning plastic at the speed I'm at now is scary enough, plus they're a lot less efficient compared to a turbo wheel.
I'm trying to make it a compact modular system so that they can be paralleled up for more power, considering it takes about 10kW of power to boost a car from 140, to around 200bhp is probably a reason they're not produced, a project never the less.
So far I'm getting around 3 psi from a 70mm diameter impeller, it's 3D printed and spinning at 60,000rpm. I'm almost ready to test out a two stage compressor with 80mm impellers, just waiting for a power source.
Posted by Muzzer on 18/10/2017 22:18:48:
Search for "electric supercharger" and you will see what the automotive companies are doing. Driving a compressor through a gearbox will be fraught, even if you don't manage to kill yourself in the process.
Be wary of the ebay "electric superchargers" that are little more than a hairdrier and can't possibly be capable of developing any kind of boost pressure at the flow rates required. If you plan to develop such a device, you should do the sums and calculate the shaft power required to compress the mass flow rate to the pressure you expect. It will be quite large…
Murray
Sorry to sound negative. I work in turbochargers and was seeing electric superchargers in development 10 years ago. Quite simply you don't stand a hope in hell but that shouldn't stop you.
Edited By Muzzer on 18/10/2017 22:44:06
Hi, Murry, should have probably read my post, I'm not making a simple 20W fan motor like those on ebay, it is actually the reason I started the project, to prove much more power is required and that the ebay units are complete junk, I'm using a 4kW system for now that will be modular for multiple units, I did state it takes about 10kW of power to boost a 140bhp car to 200bhp, that's assuming 100% efficiency. I don't understand why you don't see it's possible, the supercharger that Neil showed us from the H2R is exactly what I'm building, the difference is one is mechanical power and mine electric.
What I would agree is they're not practical since the electric system on a car is not designed for 4kW of power, let alone 10kW or more.
