Super 7 lubrication
Super 7 lubrication
Home › Forums › Beginners questions › Super 7 lubrication
  • #455499
    Sam Lawrence
      @samlawrence90272
      Hi, so I have the Super 7 running, yeehaa, having a quick look at the manual and see that I should have an "oil gun". The internet seems a bit silent about this, I'm seeing an official Myford one for 80 quid (!), is there a cheaper way of getting oil in there – will a standard oil can do it?
      Thanks
      #10105
      Sam Lawrence
        @samlawrence90272
        #455503
        John Haine
          @johnhaine32865
          The Myford oil gun is more like grease gun and famously leaky. You need a pressure gun to oil where there are grease nipples (DON'T use grease), and an ordinary oilcan for everything else.
          #455505
          Steviegtr
            @steviegtr
            Yes you need an oiling gun. Picture of mine. Cannot remember where I bought it. I think it was about £13. It seems to work ok. Depends on year of machine , but mine circa 1977 it even gets into the pulley bearing under the headstock cover. By rotating the pulley by hand it comes to a small cut out in the rear of the large pulley to the far left .
            Steve.oiling gunoil gun 2
            #455507
            Sandgrounder
              @sandgrounder
              This is a previous post of mine to another thread re' Myford oiling
              "After having had two oil guns sold as suitable for a Myford lathe ( neither came from RDG, Myford or any of the main suppliers) which did not work I decided to try something else, from eBay I bought for £7 inc' P & P a used Interlube pump type grease gun, I filled it with Nuto 32 and pumped any remaining grease out on a piece of wood, refilled the gun and did all but one of the Myford nipples with no problems at all except a small amount of oil weeping past the guns filling cap, this I cured with a plastic plug and 'O' ring to provide a seal which wouldn't have been required for grease, the only nipple it won't oil is the one in the 'V' cone pulley, the end fitting on the gun is a little too big, I haven't got around to that yet as I very rarely use the back gear."
              #455508
              Martin of Wick
                @martinofwick
                You could try Pressparts, their pressure oiler is considerably less leaky than the official version and the price retains contact with reality.
                link **LINK**
                #455517
                Sam Lawrence
                  @samlawrence90272
                  Thank you! Ordered the Pressparts version.
                  #455560
                  Steviegtr
                    @steviegtr
                    Just had a look & yes it is the same as pressparts. It comes with 2 different size nozzles.
                    Steve.
                    #455568
                    john fletcher 1
                      @johnfletcher1
                      I use an cheep diecast oil guns as supplied with some cars and mopeds years ago, which are frequently seen at car boot sales for pence. If the spout doesn't fit really tight, put a piece of clean thin rag across the oil nipple and pump the oil through it. This was sort of normal practice in the motor trade years ago. Also Nuto 32 is hydraulic fluid as used by farmers, earth moving equipment and boats. Around here we can take an empty milk carton and have it fill for a couple of pounds, worth looking around, or a group buying a gallon and share it out. John
                      #455674
                      Mark Gould 1
                        @markgould1
                        Sam,
                        Do yourself a favour and click on the link https://haythornthwaite.com/184%20Myford%20Lubrication.pdf
                        it’s an excellent guide to lubrication of your Myford.
                        Mark
                        #455712
                        Colin Heseltine
                          @colinheseltine48622
                          The Haythornthwaite document is very good, keep a printed and laminated version by the lathe.
                          Was looking for another pump gun so as to have one with Vactra No. 2 and the second with Nuto 32 so have just ordered one of the Pressparts ones.
                          Colin
                          #455774
                          Peter Spink
                            @peterspink21088
                            Interesting and useful document.
                            Against all my instincts I've heard that one should oil the clutch on the S7.
                            I've never lubricated the clutch on my S7 and it's not been a problem in the 25+ years that I've owned it.
                            Photo 5 in the document shows an arrow pointing at the clutch but no reference in the text that I can see.
                            So what's the answer?
                            #455779
                            Steviegtr
                              @steviegtr
                              Yes the bronze clutch assembly needs lube. Release the clutch arm to disengage. This opens the gap on the bronze plate. Place a few drops in there & release. Mine was noisy last week, a few drops fixed it. You would think it would make it slip but does not.
                              Steve.
                              #456260
                              Sam Lawrence
                                @samlawrence90272
                                That linky was super useful thanks. Unfortunately my oil gun won't fit into pictures 8 and 9, I assume that 8 is just lubricating the pulley wheel on the shaft?
                                #456271
                                Harry Wilkes
                                  @harrywilkes58467
                                  Posted by Steviegtr on 06/03/2020 20:54:34:
                                  Steve.
                                  I'd second Steve's remarks I do mine no issues to date.
                                  H
                                  #456275
                                  Martin Kyte
                                    @martinkyte99762
                                    If they get dry the go SCREEEEEK when you engage the cluch.
                                    Martin )
                                    #456290
                                    Sam Lawrence
                                      @samlawrence90272
                                      I did the clutch, nothing really changed so I suppose it already had a bit on there.
                                      As a ML8 user of 15 years in the day job, I cannot believe how smooth the super 7 tailstock is now it is well oiled. Like silk!!
