Stuart Twin Victoria (Princess Royal) Mill Engine
Home Forums Work In Progress and completed items Stuart Twin Victoria (Princess Royal) Mill Engine
Viewing 25 posts - 776 through 800 (of 1,286 total)
  • #611463
      You can put the dti on your sprung guide and clock the movement of the ctr hole which is how I usually do it. Back end of the guide wants to be free
      Dr_GMJN
        @dr_gmjn
        Thanks Jason, yes that what I meant. I’m not sure what you mean by back end wants to be free though?
        #611481
          Don't hold it in the tailstock chuck, mine is free to move about as it is supported with a ctr. Though a pointed long length of say 3/16" rod would flex so could be held rigidly.
          #611547
          Dr_GMJN
            @dr_gmjn
            Hmmm bit of a rubbish day on this, with little to show for a lot of effort. Same old story when turning steel – poor surface finish, plus it’s inconsistent. Also, for the lengths and step sizes I need, my HSS tool is too big and clunky – undercut lengths are huge. It didn’t give a very good finish on the actual shaft material either:
            I tried re-grinding it, touching it up on the sander to sharpen it, but I don’t really know what I’m doing. There’s no way I can get an accurate tip radii either, and every modification means re-setting the tool height. I’ve reverted to a GT insert, with finishing with wet and dry paper. It gave the same finish, and also gives much neater undercuts.
            I’ve concluded that inserts are the way forward for me since I don’t have the experience to consistently grind HSS, and it’s a difficult skill to learn from a book.
            I have at least decided to not have centre holes left in the shaft ends – I’ll face them off in the chuck. On a 9.5mm diameter shaft, centre drillings look far too big to me.
            Also realised my drawing is no good, since stepping the shaft has given me a middle section bigger than the stock 1/2” material I got. I could use the 7/16” stock, but as discussed before, it’s slightly undersized, and gives 0.002” runout after centering. It looks pretty thin before skimming it to give no runout. The step sizes also become very small. I’ll probably re-draw it for the 1/2” stuff, but ending at 12.5mm or something.
            Currently going to cut a new shaft length, and start again. Any advice on getting a good finish obviously appreciated.
            #611550
              Are you honing the HSS tool after grinding, just a rub in a diamond stone should produce a better cutting edge.
              Even with the carbide a small amount of cutting fluid will improve finish
              Not sure what size ctr drill you are using but I use a BS-0 which is 1/8" shank and a very small pilot, you only need go in a little way with the 60deg part not full depth
              Treat yourself to some 9/16" or 14-15mm bar and get some decent steps, the flywheel hub can take the extra size.
              #611555
              Dr_GMJN
                @dr_gmjn
                Thanks Jason. I’ll re-draw for 1/2” and treat it as a machining trial.
                Im not really sure what you mean by ‘honing’. I’ve got a large ‘oil stone’ for chisels, and some ARC diamond laps, but it seems like whenever I try to clean up a cutting edge, I actually get the angle slightly wrong and end up – probably – dulling the edge. I find it difficult to judge whether the abrasives are actually doing anything, often feels like they’re just skimming across the surface without touching it. The only way I can do it is by trial and error – usually error, and…it just brings me one step closer to packing up the tools and doing something else, when I really want to make progress.
                #611573
                Ramon Wilson
                  @ramonwilson3
                  Facing your centres off is your choice Doc but personally I'd just give some thought to the fact that if you need to in future – and you may – how you will hold the shaft with a fixed crank at each end and no centre.
                  I was very unfortunate to drop my Double Diagonal going up the stairs at Forncett. That bent the crank slightly enough that it could not be run. Once home and stripped down and held between centres again it was easily brought true. Not saying you might drop yours of course but there are a myriad of reasons you may want to hold it true again in the future
                  As Jason refers too use the smallest 1/8 dia centre drill and size the diameter of the countersunk hole by the depth of the drilling.
                  Sorry to hear you are finding grinding tools difficult. I can only say that practice makes perfect. If you find you get on better with Carbide then by all means use it but mastering grinding will give you another option when a suitable carbide tip isn't available. Just giving a tool edge a hone as Jason suggests is beneficial at times though not always the answer. I have a selection of slip stones however (see here) of varying section and grades to call on for that purpose. A fine grit square one and triangular section type are ideal, perhaps a round one too though not used that often.
                  Best – R
                  PS when centreing using a wobble bar as shown the bar should not rotate as the chuck is turned as a false reading can be had – it's the centre being clocked not the bar. I just hold it with my fingers as the chuck is rotated to prevent that or sometimes restrict it from rotating it by a toolmakers clamp if I need both hands.at the chuck end
                  #611584
                  Dr_GMJN
                    @dr_gmjn
                    This is the centre drill I’ve got:
                    Not sure if there are smaller ones, but by the time it gets half way up the cone it looked too big to me. The end is 1.6mm diameter.
                    The centering bar I made is spring loaded – works fine. Yes, I hold the end from rotating during measurements.
                    Thanks.
                    #611594
                    Ramon Wilson
                      @ramonwilson3
                      What is the outer diameter of that Doc?
                      The smallest standard centre drill is usually 1/8th diameter (I'm not certain if they are available in metric sizes but would have thought so – perhaps Jason knows)
                      There are smaller versions available – single ended though and quite tiny in fact but are expensive for what they are and easily damaged. The brand was 'Titex' if I recall correctly.
                      Regards – R
                      #611603
                      Hopper
                        @hopper
                        Posted by Ramon Wilson on 28/08/2022 19:01:59:
                        Reverse centre?
                        #611610
                          You can't turn to the end with a reverse ctr. or use them when the cranks are in place
                          Here are some 3mm dia valve stems being supported with a ctr drilled hole, hole must be 2mm across the top, less on the second image
                          Your picture looks like a 4mm main body with 1.6mm pilot.
                          If you come down to 1/8" imperial or 3.15mm metric then the pilot comes down to 3/64" or 1.25mm. There are smaller pilots available but I doubt they last very long, 0.025" being the smallest.
                          Edited By JasonB on 29/08/2022 07:30:54
                          #611625
                          Ramon Wilson
                            @ramonwilson3
                            Hi Hopper, fine idea as shown for the purpose shown but a shaft with fixed crank webs on each end is a slightly different matter don't you thinksmiley
                            It's not essential to leave them in – though many full size engines have them left in some don't. My thought is basic, once you machine them off – IF – you need to put it between centres again it's a bit late in the day to say 'I wished I hadn't done that. – money and choice again.
                            Doc, the Titex centre drill I was thinking of was about 3mm dia or less with a very tiny point, probably less than a mm, single ended about 20mm long.
                            I've looked but can't find it so far – personally don't think its worth it just use the smallest standard size with just enough depth to support the shaft if needed.
                            #611629
                            Dr_GMJN
                              @dr_gmjn
                              I need to sort out the turning before I can progress.
                              Do you think a left-had turning tool would be ok – no radius and the flats would be easier to grind? A bit like the boring tool geometry on the round off-cuts Ramon sent me. They seemed fairly easy to get right, although it was on cast iron.
                              Thanks.
                              #611630
                                You probably mean a right hand tool as a leftie won't cut from tailstock to shoulder
                                With the diameters you have there will be enough clearance on the 7/16" one at the end to use any tool, shape provided the two edges meet at 80deg or less you should be OK.
                                #611631
                                Hopper
                                  @hopper
                                  Posted by Ramon Wilson on 29/08/2022 09:43:01:
                                  Doh! Forgot it was a twin with the overhung crankpins. Yes, would be a bit difficult!
                                  #611666
                                  Dr_GMJN
                                    @dr_gmjn
                                    Day out today, but just wondering – are the GT inserts the best for bright steel? The good finish I got previously last week was on a mild steel off-cut. I’ll try grinding HSS again later, but I’d much rather use inserts. I’m thinking that the small angle tip I’ve got might exacerbate the surface roughness. I did try a 0.5 radius insert, but strangely it didn’t seem to make a deal of difference.
                                    Thanks.
                                    #611685
                                    Ramon Wilson
                                      @ramonwilson3
                                      Doc, things have moved on so much since I used carbide on a daily basis at work so I can't express an up to date opinion. I can say though that much heavy roughing was carried out using carbides but when a fine finish was called for to an accurate dimension HSS was always used. I know things have changed since the advent of 'CNC everything' but the old principles are just as viable today as they were then.
                                      My shaft for the Corliss shown previously was done using hand ground tools and likewise the marine engine double throw one.
                                      The quality of steel plays a part too but En1a freecutting is an ideal material for shafts running in bronze on which a mirror finish is possible from simply ground tools – worth persevering perhaps?
                                      The Titex centre drills I have are 3mm diameter with a .5mm tip – both broken regrettably but they are available.
                                      Best – R
                                      Edited By Ramon Wilson on 29/08/2022 17:17:16
                                      #611689
                                      Ramon Wilson
                                        @ramonwilson3
                                        Just checked – the small Titex centre drill is marked 'Titex Plus K1111 0.5'
                                        #611691
                                          The GT inserts are a lot closer to HSS than the MT ones so allow fine finishing cuts if you need to sneak up to a finished fit and will continue to cut whereas the MT may rub or ride up onto the surface if you try to take small cuts.
                                          Not sure where you found a 0.5 tip radius one as the usual increments are 0.2, 0.4 and 0.8 in our smaller size tips. I mostly use the 0.2. with a feed of 0.0025" per rev for finish turning. Once this focuses you can see the stream of 1thou swarf coming off and the bright finish it leaves and that is EN8 which is not quite as nice to machine as EN1A
                                          APT do the size ctr drills that Ramon mentions but in carbide, I don't think they would last long on a manual machine, HSS may fair a bit better, something like these 1mm pilot ones from Cutwel
                                          Edited By JasonB on 29/08/2022 18:21:34
                                          #611695
                                          Dr_GMJN
                                            @dr_gmjn
                                            Jason – sorry, 0.4mm tip radius.
                                            Material is 080A15 steel, in case that’s particularly difficult to machine?
                                            Grabbed a couple of hours in the workshop to try and sort this. Unfortunately succeeded only in making more swarf and steel filings.
                                            I tried grinding a right hand tool:
                                            Tried it with a slight flat to try and flatten the ridges, and a radius too, but still the same result:
                                            These are the pointed versions and another I found in a set I got decades ago:
                                            And the GT insert:
                                            Also tried a 0.4mm radius insert too.
                                            I’ve tried honing the edges with a diamond file, adjusting tool height up and down, oil lubricant, lowering the rpm, pretty much everything I can think of, but still the same result, which is like this:
                                            I’m after the un-machined finish on the left. Even when wet & dried and buffed, ridges are still visible. No use at all for a bearing surface, plus, the amount of fettling needed to get them right visually would almost certainly change their dimensions.
                                            As a sanity check to make sure nothing was fundamentally out, I turned some aluminium with no issue – both with the inserts and the HSS tools I made. Also double-checked centre heights which were also spot on.
                                            Not much point doing more until I’ve figured out what’s gone wrong here – there’s a load of steel turning to do on the connecting rods and eccentrics after this.
                                            Cheers.
                                            #611698
                                              Get some 230M07 (EN1A) which is free cutting rather than that EN3/EN32 which can be a bit gummy.
                                              #611702
                                              Dr_GMJN
                                                @dr_gmjn
                                                Posted by JasonB on 29/08/2022 19:39:58:
                                                OK I've got some EN1A just the right size, so I'l re-draw it and try again. I think it was EN1A I tried the HSS tool on the other day and it as pretty good.
                                                Unfortuntely a lot of the steel I got specifically for this model is 080A15 for some reason. I think it was specified in the instructions, or in the original Stuart parts list maybe. Anyway, that's what I ordered from my stockist. I hope it's easier to mill (but I somehow doubt it). Is there anything that can be done to it (for example heat treatment) to make it easier to machine? Otherwise it looks like replacing it all with EN1A.
                                                Or, is there a good way to improve the torn finish on non-critical surfaces?
                                                Thanks.
                                                #611712
                                                Ramon Wilson
                                                  @ramonwilson3
                                                  Doc as I mentioned in my previous post En1a is a good steel combination in a running fit in bronze (or cast iron)
                                                  It's much easier to machine than En3 or GCQ (General Cutting Quality) which is probably what you have and which will be difficult to machine to a good finish. If the tool is right it will give you an extremely fine finish straight off the tool with fine cuts and can be polished up with fine grit (240) emery or wet and dry paper.
                                                  The tool you have ground is fundamentally a reasonable basic shape but it's the tip that does the work and that needs to be improved as I see it.
                                                  The rake on the top is too obtuse for steel so increase that back towards you and back towards the tailstock – a good 10-15 degrees and the tip needs a nice radius – I do mine not by rotating the tool itself against the wheel but rather by dragging the tool at the right (as in more or less correct) front and side back off angles around the corner of the wheel allowing the radius to form by the corner of the wheel. If you are struggling to perceive this then I'll take some pics for you tomorrow.
                                                  Re material this was made from En1a and done entirely with hand ground tools – yes it's been emeried but as you have already found the finish has to be there if tool marks aren't to be evident. No form tools were used on this, the radius created by a series of flats and scraping the high points between them
                                                  Best – R
                                                  #611713
                                                  Paul Kemp
                                                    @paulkemp46892
                                                    There doesn’t look to be anything fundamentally wrong with your knife tool but the picture is a little blurry, the grinding marks on the top look quite course, what grit wheel have you got on your grinder? However if all the other tools you tried gave the same or similar effect then it’s probably not your tool! You mention changing rpm, tools, with and without cutting oil but no mention of feed rate, did you try altering that? As a test did you try different depths of cut? Does a heavy cut produce the same finish as a light cut?
                                                    As Jason says it’s likely the grade of steel you have, some low carbon steels tend to tear rather than cut, EN3B can be like that. However it should be possible to get a better finish than that although mirror finish is probably unlikely. It’s counter intuitive but upping the feed rate may give an improvement. Looking at the work piece pictures the deeper scores suggest maybe chips got trapped between the tool and the job? Flood cooling may hep that but I don’t suppose you are geared up for that?
                                                    As to improving the finish on non critical parts light use of a fine file followed by emery but mind your fingers
                                                    Paul.
                                                    predictive, chops for chips,
                                                    Edited By Paul Kemp on 29/08/2022 22:57:51
                                                    #611719
                                                    Hopper
                                                      @hopper
                                                      Posted by Dr_GMJN on 29/08/2022 19:19:30:
                                                      It's hard to tell from the pic but it looks like your tool could use a lot more angle on that top surface and maybe even a little more on the leading face. Following the advice of LH Sparey in "The Amateur's Lathe" I have found these small, not very rigid hobby lathes work best with much more of a cutting angle than usually recommended in more industrial circles.
                                                      Sparey recommends about 5 degrees of clearance on the leading face, then grind the top surface at about 30 degrees. Yes 30 degrees. This puts the knife in knife tool. So the included angle between the leading face and the top face is 55 degrees. He recommends checking this angle with the V notch in your 55-deg BSW screwcutting gauge. This angle results in a very sharp edge that cuts well — but will wear quicker than a more obtuse angled tool but seems to last ok in the home workshop.
                                                      To get a good finish it is essential to finish the tool off on a bench oil stone after grinding. The type of stone your Granny used to sharpen kitchen knives. Rub the flat surfaces on it until they are nice and flat and smooth and form a cutting edge that is sharp to the feel, like a knife. Then by rotating the tool bit as you rub it back and forth along the oil stone, put a small radius on the cutting tip, running all the way down that edge so basic cutting angles are maintained. Then stone the top surface of the toolbit to remove any burr.
                                                      And don't be shy about using a bit of emery cloth/paper and a drop or two of oil to remove the last half a thou and get the ultimate finish! By working evenly along the job you can still maintain diameter along the length within a few tenths if desired.
                                                      Also, the discoloration indicates you might be overheating your tool bit a little while grinding. Take it easy and dip in a tin of water regularly to stop the edge turning blue. Use a fine wheel if you have it for finishing. I have gone back to using 1/4" square toolbits on the Myford and packing them up, just because it takes waaaay less grinding time than the 3/8" bits that are a bit easier to use packing-wise.
                                                      See the knife tool A at the top left of the below diagram for the 55 deg included angle.
                                                      A) is a right hand knife tool
                                                      B) is a 'corner tool'
                                                      C) is a round nose tool and
                                                      D) is an example of a knife tool used for brass, you should have a round nosed and corner tool as well for brass (and CI)with the same reduced top rake.
                                                      Edited By Hopper on 30/08/2022 00:31:15
