Stuart build questions
Home › Forums › Beginners questions › Stuart build questions
  • #545483
    Nick Welburn
      @nickwelburn
      I’ve made my crankshaft and piston for the 10v today. I’ve got a couple of questions.
      the bore of my cylinder is rough. Even with a little oil it doesn’t let the piston smoothly drop.
      I guess it needs a hone. But how?
      Secondly in a moments stupidity I started on the block that the piston rod goes into. I decided to start by milling the top and bottom flat. To do this I cut the casting bar off. I now realise I needed that to use that to turn the outside diameter down. Any cunning ideas for this?
      Or should I just order an new one and think about what I’m doing before I start next time
      #10839
      Nick Welburn
        @nickwelburn
        #545494
        Former Member
          @formermember12892
          #545506
            The cheap "brake cylinder hones" on e-bay will do, probably have to be the two stone one on that 3/4" bore.
            You could tap the crosshead for the piston rod and screw it in then use the rod to hold it by in a collet, split bush or 4-jaw so the rod runs true while you turn the OD to fit the trunk guide. Bore and finish the trunk guide first then make the crosshead guide to fit
            #545520
            Nick Welburn
              @nickwelburn
              Will a 5ba thread hold the part while I turn it? Maybe if I drill and tap deeper into the block and super glue it?
              #545539
                With light cuts and a sharp tool it will, you can always bring up the tailstock ctr for added support, superglue won't make much difference.
                #545557
                mechman48
                  @mechman48
                  'The cheap "brake cylinder hones" on e-bay will do, probably have to be the two stone one on that 3/4" bore.'
                  +1, Exactly what I have, & used on my !0V, works a treat & not expensive.
                  George.
                  #545655
                  Nick Welburn
                    @nickwelburn
                    Ok – sorted that bit and learned not to start cutting without a plan for all operations! Will get a hone on order quick zip with the dremel and a polishing pad has helped considerably. May try the dremel with some valve grinding paste and see what does.
