Stuart 501 boiler
Stuart 501 boiler
Home › Forums › Stationary engines › Stuart 501 boiler
  • #3322
    Maurice Cox 1
      @mauricecox1
      #328535
      Maurice Cox 1
        @mauricecox1
        I recently acquired a Stuart 501 Boiler. It still had the asbestos boards on the inside of the side plates. This has been safely disposed of. Can anyone suggest a replacement material, and where to get it please?
        Maurice
        #328537
          You could pop into a good builders merchants or roofing suppliers and by an "undercloaks board". These a fibre cement boards about 4ft long and 6" wide so enough for your boiler, cost about a quid each
          #328539
            Kaowool is OK if it is supported. If it needs to be self-supporting try a Skamolex (vermiculite) board, OK up to red heat – you can cut it into thinner sheets with a saw (use some sort of guide).
            Maurice Cox 1
              @mauricecox1
              Thanks Jason, that sounds promising. I'll try that.
              #328615
              Keith Hale
                @keithhale68713
                Available ex stock from CuP Alloys.Keith
              Home › Forums › Stationary engines › Topics
