The bed castings for the older 3 Vee bed Boxford lathes were “weathered” for 6 months before finish machining. There were pallets of bed castings around the works yard, and they were copiously watered daily witha hosepipe (when it wasn’ t raining or snowing !).
It was not unknown for some of the workforce to “water” them as need arose, either !
After 3 months the castings were shot blasted & “topped and tailed” – rough planed top and bottom – then put oustside for another 3 months of “weathering”. After another sholblasting, they were filled and painted before finish machining – bottom planed & top “gang-milled” to produce all the vees, flats & sides at one pass on a very robust Russian-built duplex head horizontal mill.
The later hardened bed machines were just being developed & put into production when I was there. The bed castings for those came in “stress-relieved” from the foundry – no “weathering”, they went straight from the delivery to production. There were some “issues” with the beds moving during machining. The beds had the top formation gang-milled as with the older machines, then they went on to a fixture on a new Snow grinder with a Radyne induction hardeneing plant mounted at one end. The bed passed slowly under the induction hardening device, which locally heated a small area to bright red heat, which was immediately quenched with coolant. After hardening, the grinder table was moved under the wheel for grinding the top formation in one pass, the wheel being dressed to shape by a special diamond dresser.
I seem to recall that the trial beds were not straight & the “old hands” were keen to blame the stress relieved casting – no substitute for weathering ! The answer, if I recall correctly , was to pre-stress the bed by tightening a clamp in the middle of the bed (with a torque wrench to apply a repeatable load) before hardening. This clamp was released before grinding. Result – straight beds without weathering.
I have – somewhere – photos of this hardening & grinding process. I got a Praktica MTL3 SLR for my 21st birthday & one of the first films I exposed though it was around the Boxford works. This was April – May-ish 1981. Seems a long time ago, now !
Nigel B.
