Straightening brass tweezers
Home › Forums › Clocks and Scientific Instruments › Straightening brass tweezers
  • #331607
    Steve Crow
      @stevecrow46066
      I have had a pair of Bergeon brass tweezers for about 3 years now which I use a lot.
      Iv'e noticed that the tips no longer meet – they are very slightly splayed out for the first millimeter.
      Has anybody any tips on straightening these? I didn't want to just dive in with a pair of long nosed as they are not cheap to replace.
      Many thanks
      Steve
      #3778
      Steve Crow
        @stevecrow46066
        #331610
          Steve,
          I would gently clamp them onto a suitably sized rod and then 'burnish' them back to shape.
          … Hope that makes sense.
          Bob Stevenson
            @bobstevenson13909
            Exactly what Michael said!……he literally took the words out of my post!
            Burnish back into shape and then put them on ebay and buy a decent pair…… At Epping Forest Horology Club we have many Bergeon items and in every case without exception they are massively overpriced and can be surpassed by a MUCH cheaper alternative…watch screwdrivers (£168 a set!) no better than a cheap set costing a fiver………clock spring winder which flimsy and poorly designed for the huge price………Watch clamp that is no better than our market stall alternative!!……
            #331644
            Ian P
              @ianp
              Michael
              How does burnishing change the shape of a part?
              I can see that on a microscopic surface level it might change the size of a part but curious how it could reverse the splayed tips.
              Ian P
              #331646
                Posted by Ian P on 11/12/2017 21:37:35:
                Michael
                Ian P
                Ian,
                I closed with the comment: "… I hope that makes sense."
                Clearly it did to Bob, but not to you.
                When I used the term 'burnishing' [in quotes], I meant the process of using a burnisher to gently work the tips back to a good shape … The 'suitably sized rod' provides supprt and acts as a former.
                It's rather like the 'rubbing' process that jewellers use to set cabochon stones, or lens-makers use to mount elements … but linear.
                Does it make sense now ?
                Edited By Michael Gilligan on 11/12/2017 21:49:50
                Edited to correct spelling of cabochon
                Edited By Michael Gilligan on 11/12/2017 21:59:02
                #331647
                Ian P
                  @ianp
                  It sort of makes sense if I imagine that the burnisher pressure gradually bends the tip in a series of small amounts rather than bending it in one go.
                  Maybe its a sort of Uri Geller effect!
                  Ian P
                  #331654
                    With stainless steel ones, I gently draw the outside on a flat surface, point last, and they gradually straighten.
                    #331770
                    Steve Crow
                      @stevecrow46066
                      Thanks to all for the advice.
                      Michael, I'll try the trick with the burnisher.
                      Bob, I hear what you are saying about Bergeon products. The problem is, when it comes to brass tweezers there doesn't seem to be anything in between cheapos (which are rubbish) (2 – £3) and Bergeon (£30) and Dumont (£40). You mention screwdrivers. I need a couple of larger ones (2.5 and 3.0 mm) – I don't need a set. What would you recommend?
                      Many thanks
                      Steve
                      #331785
                      KWIL
                        @kwil
                        Bergeon do a set of 5 for a lot less than mentioned. £35, still not cheap but not rubbish.
                        #331790
                          Posted by KWIL on 12/12/2017 19:27:17:
                          A useful 'guide' is available here: **LINK**
                          https://www.eternaltools.com/blog/complete-guide-to-watchmakers-screwdrivers
                          Worth a read, I think.
                            Posted by Steve Crow on 12/12/2017 18:02:42:
                            Many thanks
                            Steve
                            Don't laugh, but if you aren'tbrying to find brass screwdrivers this is the best set of small screwdrivers I have ever used, even if the handle is a bit plasticky the blade quality is excellent:
                            Ian P
                              @ianp
                              Posted by Neil Wyatt on 12/12/2017 20:15:06:
                              What is the A/F size of the bits?
                              I'm hoping its 4mm the same as the Wiha ones.
                              Ian P
                              #331794
                                I bought a set of those a few years ago, Neil
                                I too was very impressed; until I found that one of the Torx tips was horribly mal-formed.
                                … The usual 'customer does the quality control' situation, I'm afraid.
                                Wickes happily gave a full refund, so I can't complain … but I have never since found anything to compete.
                                [maybe I should have kept them]
                                Anonymous
                                  Posted by Ian P on 12/12/2017 20:25:15:
                                  Ian P
                                  You're in luck Ian they are 4mm A/F thumbs up . I've got a set,different/ better handle than Neil's link, can't remember if it was Wickes or somewhere else I got them a couple of years ago.
                                  #331812
                                    Yep, 4mm a/f.
                                    #331856
                                    Ian P
                                      @ianp
                                      Thanks Mick/Neil, a set is in stock at my nearest Wickes and it just so happens that my good lady is presently in the adjacent emporium so is collecting for me.
                                      I already have about 20 Wiha bits and several handles for their 'System 4' range but individual bits are both expensive and not easily available so these Wickes ones are too good to miss.
                                      Ian P
