Straightening brass beading
Home Forums Beginners questions Straightening brass beading
  • #8969
    Clive Brown 1
      @clivebrown1
      #327132
      Clive Brown 1
        @clivebrown1
        Hi,
        I need to solder 3/16" half-round brass beading along the top edges of the loco tender that I'm building. Since this stuff arrives as a coil, it needs to be straightened. The 2 main lengths will each be around 20", if it's not straight It will stick out like a sore thumb.
        Any tips for doing this will be much appreciated.
        TIA
        #327147
        Trevor Drabble 1
          @trevordrabble1
          Clive , Suggest you have a look at a pyro straightener at your local electrical distributors or on line . BICC do a reasonable one .
          Trevor.
          #327151
            Put one end in your vice, grip other end with mole grips and then give a sharp pull on the mole grips to stretch the beading taught, that should do the job
            #327152
            Tim Stevens
              @timstevens64731
              Jason beat me to it. A good trick for any wire less strong than music wire, in my experience. It would work with music wire too, but holding it is more difficult, pulling hard enough even more so.
              Cheers, Tim
              #327366
              Clive Brown 1
                @clivebrown1
                Thanks for comments. The straighteners look surprisingly effective in the on-line videos, but I think I'll try a good strong pull. I'll probably need some mechanical advantage though!
                #327368
                Martin Connelly
                  @martinconnelly55370
                  If pulling does not work then try twisting it. One end in the headstock chuck and the other end in the tailstock chuck with a little bit of tension. Turn the chuck by hand.
                  Martin C
                  #327377
                    Posted by Martin Connelly on 15/11/2017 18:59:44:
                    Martin C
                    Does that work on half round beading? I've used it on round wire but would have thought the flat of the HR beading would end up in a spiral?
                    #327527
                    Martin Connelly
                      If you twist half round one way then reverse the twist direction it should straighten it but leave it flat. Just don't overdo the amount of rotation applied.
                      Martin C
