Advice please…
The quill travel on my Myford mill is very sticky, to the point that is useable but lacks drilling sensitivity and its return-spring won't return it.
Thinking – simple solution first, ensure the clamp is not jammed. It was not, but I cleaned and oiled it before replacing it.
Broken or unhooked spring? I do not have the appropriate tools and knowledge, beyond knowing that handling powerful clock-springs without is hazardous and very difficult. Luckily, VERY careful inspection suggested the spring is intact.
So could the problem be dried grease on the rack and pinion? If so can this be sorted with the machine intact or would I need to remove the head – as I suspect? I know I'd need to tram the re-fitted head, but I have an indicator for this purpose, bought from this Forum's sponsor!
I have a copy of the manual, which gives a sectional drawing, but does not advise on taking the thing to bits and re-assembling it.
All help gratefully received!
