SRDCN Profile tool
SRDCN Profile tool
Home › Forums › Workshop Tools and Tooling › SRDCN Profile tool
  • #315011
    Shaun Trewinnard
      @shauntrewinnard48432
      I have a SECO SRDCN 16×16 profiling tool – two questions:
      This tool takes an 8mm button tip. Unfortunately through fair wear and tear the key to release the tip has worn the socket screw to the point where I cannot free the tip. Any suggestions would be most welcome as these are expensive tools.
      In the case that the tip cannot be released can anyone suggest a supplier so I can purchase a new one.
      Always rely upon a fount of knowledge out there – Shaun
      #18637
      Shaun Trewinnard
        #315016
        Steve Pavey
          @stevepavey65865
          There is a spares catalogue here which lists your toolholder and gives the order number for a replacement screw. The UK agent is
          Seco Tools (UK) Ltd
          Adams Way, Springfield Business Park
          Alcester
          Warwickshire B49 6PU
          Tel: 01789 764341
          Fax: 01789 761170
          You might be able to bring the head off the screw with a Dremel, or maybe unscrew it with a left hand drill bit, or even hammer a bit of copper or brass rod into the screw head and use that to unscrew it.
          #315020
          Robbo
            @robbo
            Try some folded tinfoil over the socket and hammer the key in, might give you enough grip. Or take the next size up key and hammer that in.
            #315027
            Muzzer
              @muzzer
              The inserts will be quite brittle, so if you are struggling to remove the screw, you could shatter the insert with a hammer etc as a last resort. That should leave the screw accessible and unloaded (ie loose), I'd imagine.
              Murray
              #315031
              Chris Evans 6
                @chrisevans6
                A lot of these screws have another hexagon on the underside. Failing that I have drilled many of these out over the years. Edit most times easier to drill from the underside to ensure on centre of screw.
                Edited By Chris Evans 6 on 03/09/2017 15:15:24
                #315187
                Shaun Trewinnard
                  Thanks for the replies everyone – I think I'll try SECO ltd. first and use a Birmingham screwdriver as a last resort.
                  Anyway many Thanks – Shaun
                  #315192
                  Mick B1
                    @mickb1
                    Another possibility – carefully grind a few thou off the tip of the key to remove the rounded edges and expose sharp corners.
                    Sometimes it works.
