Springing for Achilles
Home › Forums › Help and Assistance! (Offered or Wanted) › Springing for Achilles
  • #495455
    Brian Pritchard
      @brianpritchard66881
      I am working on overhauling an Achilles Loco . The drawings specify 18g springs but there is no mention of length. I have a set of springs from Reeves, they are 1 1/4" x 5/16 x 18 gauge. The length of the pins is 1 1/4" which if the axle boxes are raised by 1/8" the length to fit the springs would be about 7/8". Would this be a suitable length with which to start?
      Thanks
      #33674
      Brian Pritchard
        #495632
        Howard Lewis
          @howardlewis46836
          How much travel do the axle boxes have within the hornblocks? If you want to use all ,of this distance, you cannot have springs which are chock before this.
          How many turns do the springs have? This will determine the sold length of the spring (Turns x 0.048 )
          If this is more than your 7/8 space, the springs are unsuitable.
          Shortening a spring by cutting off turns will increase the rate, but increase the stress in the spring, possibly to point where it will fail when repeatedly fully loaded.
          You need to check the rate of your springs.
          18SWG is 0.048 diameter, so allowing 1/4" travel the spring would be solid in the remaining 5/8, if it had 13 turns..
          Really, the spring rate (lbs / inch ) will be determined by the amount of travel that you want, given the number of springs to carry the weight of the loco, for a given deflection of axle boxes.
          Say you have 8 springs ( 2 per axlebox on an 0-4-0 ) carrying a loco weighing 112 lbs, (to make the arithmetic easy ), and your desired axlebox travel is 1/4"; .so each spring needs to have a rate of 56 lbs / inch.
          HTH
