Plenty strong enough for bolt hexagons and the like so long as you are sensble about cutter size and cut. For example I knocked out a 17 mm A/F hex on 20 mm nominal, actually a touch under, the other day using a 3/8" cutter in one pass per side. I'd advise using the locking screw too rather than relying on the pin alone even though the screw and thread is a bit um lacking in precision. Been meaning to modify mine with a proper split collet clamp for 20 odd years but never got enough roundtuits to pay for the job.
Do trim the sides of the base up to match your milling table slot spacing so you can align it with a parallel in the slot. Useful if the spindle axis aligns with a table slot too but thats really only possible for those of us with larger machies such as Bridgeports. Probably worth fitting a couple of alignment keys in the base too for rapid set up. Plain dowels will be fine. I've not done this but really should. On smaller machines you may be able to drill the base in line with table slots so you can bolt it down directly. Which is best way. On my Bridgeport I use the usual Tee stud, bar and step block clamps which works. A larger sub base to cover Tee slot spacing is another thing I've not got round to. Sometimes I just clamp it straight in the vice.
I also have a small 3 jaw chuck on a 5C arbor which is very useful.
Clive.
Edited By Clive Foster on 19/03/2016 09:43:00
