SPG Tools
SPG Tools
Home › Forums › Beginners questions › SPG Tools
Viewing 6 posts - 26 through 31 (of 31 total)
  • #324676
    mark smith 20
      @marksmith20
      Hi Steve it may be but i dont think its sheared ,it certainly wont turn . The bits in the middle of the long bar are certainly not the same as mine despite being it the manual.Mines just a straight long bar with the worm possibly pinned on one end and the handwheel/dial on the other fixed on with a socket head grub screw..
      #324683
      Bazyle
        @bazyle
        Although this started as and SPG thread it is probably fair to say many of the similar offerings by other importers are likely to be the same and there may be some suffering Friday-fit variation in quality.
        This whole mechanism concept is standard for moving quill mill/drill functions right up to a Bridgeport probably with inevitable drawbacks from the mixture of worm and rack suffering in the hobby models from cost saving> poor engagement>jerky movement.
        If you want a precision down feed add a proper leadscrew at the side. Otherwise longer term you might need to look at adjusting the rack>pinion depthing as well as the worm>wheel depth when you fit a proper wormwheel.
        My earlier suggestion was a 'get you home' especially for beginners who perhaps got the mill second hand and already worn and while not an optimisation of the design is no worse than as original so should last long enough to learn worm wheel cutting.
        #324684
          Why not lengthen the hole in the block so you can get better mesh?
          Leave it in the worn alignment, it's gradually turning the gear into a proper worm wheel…
          mark smith 20
            @marksmith20
            Looks like others have had similar problems with fine feed not working  with the same mill on here before. notice the same shaft with none of the linkages in the middle like the on the parts  diagram .
            Edited By mark smith 20 on 31/10/2017 18:06:01
            Edited By mark smith 20 on 31/10/2017 18:07:47
            #325014
            Howard Lewis
              @howardlewis46836
              Coming in late, as usual, presumably the normal up and down movement via the handle still work?
              Otherwise the problem may not be the worm and wheel, but somewhere in the Rack and Pinion area.
              #325026
              Roger Clark
                @rogerclark
                The mill now comes with the pulley and belt conversion at least the one I bought earlier this year did.
                I found the only way I could get round the backlash causing dig ins was to ensure that you kept pressure on the handle while adjusting the fine feed down. I have bought and installed the dro system that he sells. Seem to be fairly accurate, at least as accurate as thr mill will allow it.
                I am managing to work down to hundredths of a mm with care and patience and sharp tools.
                Roger
