Speedy lubrication
Speedy lubrication
Home Forums Locomotives Speedy lubrication
  • #1483
    Speedy Builder5
      @speedybuilder5
      Why check valves
      #218214
      Speedy Builder5
        @speedybuilder5
        I notice on LBSC's drawings that there are 2 check valves for cylinder lubrication. One is on the lubricator and the second is in a "T" fitting which goes to the cylinder steam pipes. Is this 'normal' practice or 'over kill" ?
        BobH
        #218361
        stan pearson 1
          @stanpearson1
          Hi Bob
          I have built LBSC`S 31/2" Black 5 Doris and it has the same one in the oil pump and one in the tee for the cylinder feeds, I think you would getaway with just the one in the pump but I went with the drawings.
          Stan
          #218383
          Speedy Builder5
            @speedybuilder5
            Thanks for the reply Stan, I have also looked in Martin Evans's book where he states 2 check valves. I just wonder if you don't have a valve near to the steam pipes, then steam could condensate in the oil delivery pipes a bit like a displacement lubricator, but oil would eventually be delivered.
            I would still like to know the reason why ?
            BobH
            #218415
            nigel jones 5
              @nigeljones5
              IMO it is because getting non return valves to work properly with steam oil – and remember it should be warmed before being pumped – is a nightmare!
              #218419
              Speedy Builder5
                @speedybuilder5
                Thanks Fizzy. You say "warmed" before pumped, there is no provision for this on SPEEDY, but the pipes do pass thro the smokebox after pumping. Do you reckon that that was sufficient?
              Home Forums Locomotives Topics
