Special ER Collets
Special ER Collets
Home Forums Workshop Tools and Tooling Special ER Collets
Viewing 16 posts - 26 through 41 (of 41 total)
  • #233706
      The ratio of bore to supported length is important.
      Russell Eberhardt
        @russelleberhardt48058
        Posted by Neil Wyatt on 07/04/2016 20:00:14:
        Please explain. What is the effect if the ratio is wrong?
        Russell.
        #233858
        Michael Briggs
          @michaelbriggs82422
          If I need to hold a short workpiece in an er collet, I put a short piece of the same diameter in the back of the collet as Gordon and Michael have said, works a treat.
          Edited By Michael Briggs on 09/04/2016 10:16:51
          #233862
            Here is a useful collection of information:
            The comment about the holding capacity of ER-MB collets is interesting.
            P.S. Here, for Lottery winners, is the Regofix catalogue.
            The warning on p24 of the PDF is pertinent to this thread.
            Edited By Michael Gilligan on 09/04/2016 11:14:25
            #233877
            Howard Lewis
              @howardlewis46836
              Russell,
              Length/bore ratio
              Just think about pulling sideways on the top of a 1 metre post that is 10cm into the ground. It will wobble!
              If you are lucky, the short work won't come out as you cut!
              #233892
              Russell Eberhardt
                Posted by Howard Lewis on 09/04/2016 12:47:25:Just think about pulling sideways on the top of a 1 metre post that is 10cm into the ground. It will wobble!
                I wouldn't call a 1 m bar short! My point is that ER collets maintain parallelism as they close so there is no point in putting a supporting piece in the rear of the collet.
                No luck involved, just usual care.
                Russell.
                #233904
                Douglas Johnston
                  @douglasjohnston98463
                  I am not so sure they can maintain parallelism if there is only contact at one end. You may well be right Russell but I can't help feeling the need to support the other end.
                  Doug
                  #233942
                    Posted by Russell Eberhardt on 09/04/2016 10:01:42:
                    Russell.
                    The leverage a part in a collet has that allows it to distort the collet depends on the supported length. Smaller parts have less strength and will bend before they distort the collet so they don't need as much support.
                    Roger Head
                      @rogerhead16992
                      Posted by Michael Gilligan on 09/04/2016 10:56:44:P.S. Here, for Lottery winners, is the Regofix catalogue.
                      Well spotted, Michael. Makes sense, really. (For others, it's p3 of the catalogue numbering, p24 of the pdf file). Not normally a problem for toolholding, but a definite concern for holding short workpieces. Rationally-priced ER collets are lax enough in their run-out performance without adding our own distortions.
                      Roger
                      #233966
                      John Haine
                        @johnhaine32865
                        I think a factor must be the different tapers on the front and rear of the collets. I suspect the closing force at the rear is greater as the taper is more gradual and friction between the socket and the collet less significant. The front taper is much steeper. Imagine that the taper was actually 90 degrees at the front, there could be no closing force. So a short workpiece that only enters the front of the collet may not be held so tightly.
                        #233970
                          Looking at Michael's link what always fascinates me is that the tightening torques for collets are (at the recommended 80% of maximum) comparable to what you would use for diesel engine cylinder head bolts…
                          Hands up anyone here who pulls over 100lbs on the end of their 8" long ER25 collet spanner?
                          Peter Krogh
                            @peterkrogh76576
                            Posted by Neil Wyatt on 10/04/2016 08:44:02:
                            I'm looking at ERs for my little mill, and was shocked when I saw the torque spec for an ER-32 nut!!
                            I'm with Neil in asking this question…..
                            Pete
                            #233980
                            Gordon W
                              @gordonw
                              Maybe the torque setting is the max that the threads will stand ? I have a ER32 ( best thing I've bought, so far ) And usually just hand tighten the nut, holding the spindle with a tommy bar. This is for workholding not toolholding.
                              #233981
                              Anonymous
                                I don't faff around with a mere 8 inches. I use 12" spanners on my ER20 collets. Of course I only use them for tool holding, and that I think is the point. Milling cutter shanks are hardened so the gripping force relies almost entirely on friction. To obtain a high value the nuts need to be done up very tightly.
                                #233982
                                ega
                                  @ega
                                  My ER40 collet spanner is getting on for 1' long.
                                  #233989
                                    I use a puny 4" tommy bar and an 8" c-spanner with as much force as I can muster, but nowhere near 130Nm on such short tools. the tommy bar is an 'interesting' shape.
