soldering brass
soldering brass
Home › Forums › Beginners questions › soldering brass
  • #9681
    Roger Hulett
      @rogerhulett83124
      #411159
      Roger Hulett
        @rogerhulett83124
        I am beginning to assemble my brass,home made carburettor. I have faithfully copied the original. It is necessary to solder the parts together. However, some parts have to be soldered to other parts that have already been soldered. Is there a technique for keeping the old parts cool whilst heating up adjacent parts for soldering. The parts can not be soldered simultaneously.
        #411165
        Ian P
          @ianp
          Usual method is to use two or more solders with different melting temperatures, (use the higher temp one first)
          Ian P
          #411167
          Jeff Dayman
            @jeffdayman43397
            You can use the old trick of wrapping the end you want to keep cool in a wet rag, or embed it in a cold raw potato.
            Sometimes just clamping on a hemostat or attaching a piece of copper sheet with an alligator clip will do.
            Good luck!
            Edited By Jeff Dayman on 27/05/2019 17:17:38
            #411711
            Roger Hulett
              @rogerhulett83124
              Further to this topic, adjacent to the item being soldered there is a threaded section. Obviously I don't want to let the solder run into this area. Is there an anti flux,something that prevents the solder running into the threads….. Vaseline,grinding paste,butter, 3 in i oil ?
              #411714
              Former Member
                @formermember19781
                #411719
                BC Prof
                  @bcprof
                  If its silver solder I use either "lead" from a pencil of Tippex correction fluid . Never tried it for soft solder
                  Brian C
                  #411734
                  John Billard 1
                    @johnbillard1
                    Tippex works for soft solder.
                    John B
