Soft Carbide
Soft Carbide
Home › Forums › General Questions › Soft Carbide
  • #331862
    Ian P
      @ianp
      The link below is to a nice looking small machine vice which purports to have a hardened body but 'soft' carbide jaws.
      I've not heard of this material before but wonder how soft it is
      Ian P
      Ian P
        @ianp
        Is this a good thing for vice jaws?
        #331865
        MW
          @mw27036
          Hi Ian,
          I think the description has made things slightly confusing, because although the material is carbide,
          I think they are describing the fact that the jaws have a plain flat face rather than the diamond pattern grippy ones that you often see on bench vices. I have heard the term "aviation" style jaws when they are flat faced for non marking.
          Michael W
          #331868
          ega
            @ega
            Ian P:
            Interesting; why not put your question to the seller via his website?
            #331869
            Clive Foster
              @clivefoster55965
              Carbides come in a wide range of different grades, basically depending on relative proportions of carbide and binder, usually cobalt. Lower percentage of binder makes for a hard but more brittle carbide. High percentage of binder makes for softer but tougher carbide.
              So presumably jaw faces are a large piece of carbide with high proportion of binder giving a, hopefully, better balance between toughness and face hardness than the usual tool steel. Possibly a bit gripper too.
              Apparently you can now get stone brushes (whatever they may be) with soft carbide bristles!
              Clive.
              #331879
              Ian P
                @ianp
                Posted by ega on 13/12/2017 12:41:06:
                Ian P:
                Apparently it is an error in the description. They have told me the jaws are soft so you can 'modify them to suit your own purposes'
                Ian P
                #331880
                V8Eng
                  @v8eng
                  Cooksons have an offer today, worth checking out if anyone is thinking of ordering.
                  I have no connection to them just a satisfied customer.
                  Edited By V8Eng on 13/12/2017 14:00:51
                  #331887
                    'Offer excludes Gold Bars' thought I could make a killing there…
                    #331897
                    Mick B1
                      @mickb1
                      Posted by Michael-w on 13/12/2017 12:21:48:
                      Hi Ian,
                      Michael W
                      I'd always thought that flat, hardened jaws were 'toolroom' jaws, 'cause that's where I got my Record vice from when they closed the tooling department of the teleprinter factory where I was a tool designer. I don't think I'd want diamond pattern jaws now.
                      #331899
                      MW
                        @mw27036
                        Posted by Mick B1 on 13/12/2017 16:30:32:
                        Hi Mick,
                        I think you'd also be right, I think the name has a local connection for me, as I live just down the road from what was the old british aerospace engineering plant, now MBDA.
                        I only use the diamond jaws on my bench vise for hacking up blocks of whatever, but having said that I quite often use two bent pieces of ally plate in between for delicate stuff, maybe I should look at machining some flat jaws.
                        Michael W
                        #331922
                        V8Eng
                          @v8eng
                          Posted by Michael-w on 13/12/2017 16:42:20:
                          Michael W
                          I thought that is what 1" x 1" Ally Angle is made for!wink
                          Edited By V8Eng on 13/12/2017 19:05:10
