Smoothing Tool
Smoothing Tool
Home › Forums › Workshop Techniques › Smoothing Tool
  • #843630
    Vic
      @vic
      Anyone made one of these? Hopefully folks can see the link?
      https://www.facebook.com/reel/883259387897553/?fs=e&fs=e
      #843639
      bernard towers
        @bernardtowers37738
        looks nice its the terendy thing at the moment what about dimensional control???
        #843640
        old mart
          @oldmart
          It is a simple burnishing tool I noticed one for sale on ebay today. You could make one if you had grinding and hardening setup in the workshop. The ball is just a ball bearing.
          #843666
          Dalboy
            @dalboy
            Excuse my ignorance but which parts would need grinding and hardening as I thought that the races of bearing and bearing balls are already hardened.
            #843667
            Vic
              @vic
              Yes, that’s what I thought? As seen in the linked video, it’s used well lubricated.
              #843674
              Bazyle
                @bazyle
                Bit like a single wheel knurl I assume you preferably need a bigish lathe to apply enough pressure ?
                #843677
                Clive Foster
                  @clivefoster55965
                  Just using the outside of a decent bearing without the intervening ball can work pretty well. I imagine more pressure will be needed just using the bearing than with an interposed ball as shown. Effectively larger width of cut equivalent with the bearing alone. Perhaps if you tilted it to use the edge chamfer the forces would be usefully less. Bearing alone device worked well enough for me the one time I tried an experiment with the shop-made one that came with my P&W B. But I’m full size machine guy, not home shop small bench mount, so can push harder.
                  One day I may need it for real.
                  Can’t see any great need for hardening. Simply making it out of one of the more obdurate steels should be fine. Only high pressure contact between ball and housing is at the side as it is moved back and forth. Flood oiling should ensure plenty of life for our levels of use. I’m inclined to wonder if the bearing pushing the ball is strictly necessary. Plain socket with plenty of lubrication might be enough. But it is important that the ball doesn’t stall.
                Home › Forums › Workshop Techniques › Topics
