Smoothing a Cast Iron Wheel
Home › Forums › Beginners questions › Smoothing a Cast Iron Wheel
  • #319283
    Malcolm Farrant
      @malcolmfarrant93389
      I am dealing with a cast Flywheel, there are on it 6 spokes. Does anyone have any brilliant ideas as to how to shape and smooth these other than patiencec and a file, or several files.
      As always in anticipation THANKS
      Malcolm
      #8888
      Malcolm Farrant
        Smoothing the Spokes on a cast wheel
        #319286
        Phil H1
          @philh196021
          Malcolm,
          I have very successfully used a Dremel type drill with various abrasive wheels and diamond burrs on model locomotive wheels (10 wheels with many spokes). However, with just six spokes, I would imagine that a couple of hours with a few hand files would sort a flywheel out. Maybe a couple of strips of emery cloth too.
          Phil H
          #319287
            Hand files work for me to get rid of any flash and any steps where the two halves don't quite line up. I do often follow that up with a Dremel with grinding bit in it to take off any excess roughness left from the sand
            #319295
            Nick_G
              @nick_g
              Same as Jason. Files, Dremel and a smear of Isopon P40 after wiping with acetone for any low points or places where I have got over enthusiastic with the first two.
              A quick dusting flick over with spray primer will easily reveal any areas you may have missed that need further attention.
              Nick
              #319319
              john carruthers
                @johncarruthers46255
                I resorted to a diamond file for a hard wheel, only took a couple of hours to clean it up.
                #319326
                  Dremel and files here too.
                  Take it steady and it's quite therapeutic.
                  Malcolm Farrant
                    Thank you all for your assistance.
                    Yes it is as I thoght a case of Patience, Patience, Patience….I am better at that than I am with the tools !!
                    Hopefully I will make a good job of it
                    Malcolm
                    #319651
                    Nick Hulme
                      @nickhulme30114
                      In the past I had to finish the surface of some stainless rings formed from round bar, I used home made sanding belts from sheet abrasive, you have to glue them together in-situ around the part with the abrasive on the inside. I drove them with an expanding rubber Dremel drum sanding mandrel with a plastic washer on each end to stop the belt slipping off and the drum tightened enough to give a crowned pulley shape to help belt location.
