Smart and Brown 1024 Lathe
Home › Forums › Manual machine tools › Smart and Brown 1024 Lathe
  • #490565
    Peter the Great
      @peterthegreat
      Hello,
      I'm hoping that one of the members might have some experience with the above model lathe.
      The power feed function to carriage and crosslide stopped working, although the feed shaft continued to rotate.
      I later found the (worn) key from the feed shaft in the chip tray, I aligned the keys ways and put the key back in and turned it over by hand and all seems well.
      Any advice or drawing on how this key should be retained would be much appreciated. I’m really hoping to avoid a carriage / apron strip down
      Thanks
      Peter
      #13997
      Peter the Great
        @peterthegreat
        Power feed problem
        #490568
        JohnF
          @johnf59703
          Peter, its a long, long time since I had mine apart but if you PM me with your email I do have a pdf & jpg copy of the manual which may be some help. Its just sectioned diagrams/drawings of the machine sections with all the part numbers on — no explanations but it will assist in what is where.
          Peter the Great
            @peterthegreat
            Hi John,
            Much appreciated. PM sent
