Posted by ega 14/01/2019 10:58:45
In the introduction to his 1997 book Harprit Sandhu invites corrections.
I wonder whether it would be possible for him to be invited to comment?
I bought the book partly because, having faced the challenge of building
the Quorn spindle I was interested in knowing if there were easier ways
to achieve the desired result.
Edited By ega on 14/01/2019 10:59:05
I too have built a Quorn spindle and with care they run well ,it must have done
as i have had it 30 years and it has never been apart.
The photo shows 3 grinding spindles under construction,based on the layout
of the Quorn type spindles with modifications.
The outer sleeve is bored through for a close fit for the bearings,in this way
the bearings will be in line axially.
The shaft is made with bearing seats this gets rid of the bearing spacer tube
and makes the shaft much stronger as it is larger in diameter in the central
portion.
The two sleeves seen in the photo, the shorter one is eventually loctited into
the outer sleeve in the correct position ,the longer sleeve forms the spring box
to push on the rear bearing much the same as the Quorn design.The spacing
of the bearing seats on the shaft is a few thousanth's more than the total
length of the two sleeves limiting the amount of axial movement.
The two screwed end caps similar to the Quorn ,the front one traps the
outer raceway ,the rear cap is clear of the bearing.
In this way a nut fixing is required at both ends of the shaft to trap
the inner raceways to the shaft, as these form part of the labyrinth
seals these are much easier to do.
Perhaps the biggest advantage of constructing in this way is that all
of the turnings are single operations and require no turnarounds for all
of the important features.
The bearings are SKF C3 Eco 17x 35 mm bearings rated for 25,000 rpm
and are more than good enough for the expected loads,i expect that
angular contact bearings a better bet if the spindles were to be used
for milling.
