Small lathe dial suppliers
Home › Forums › Workshop Tools and Tooling › Small lathe dial suppliers
  • #544218
    swood1
      @swood1
      Hi all,
      Does anyone have a source for small diameter dials for a small watchmakers lathe?
      OD – approx 20mm
      ID – approx 10mm
      scale – 50 divisions.
      Steven
      Steven
      #20283
      swood1
        @swood1
        Watchmakers lathe
        #544224
        Journeyman
          @journeyman
          Would be useful to know the make and model of lathe, someone might know where spares are available.
          Not too difficult to make one on the lathe given minimum equipment. If a chuck or faceplate is available measure the diameter, calculate circumference, divide by number of divisions. Cut paper strip to length and mark on divisions, wrap around chuck/faceplate and rig up suitable pointer. With care can be quite accurate and use this to mark out dial held in chuck or on faceplate use a lathe tool mounted sideways to cut cut divisions. Have a look at my website ** Journeyman's Workshop **  for more detail.
          Failing that 3D print one if you have a printer or know someone that has one. Will be sufficiently accurate and should last reasonably long time.
          Edit: Add link
          Edited By Journeyman on 10/05/2021 14:19:53
          #544229
          swood1
            @swood1
            Thanks John,
            Your response gives me options. The cross slide I have been designing and making myself so it's not specific to a manufacturer but I like your idea of marking a faceplate for the divisions.
            Out of interest I was looking at a cross slide leadscrew with a 1mm pitch, Would it make more sense to have 100 divisions on the cross slide dial?
            Steven
            #544231
            Journeyman
              @journeyman
              Whilst the 1mm pitch is a good idea I doubt you would get 100 divisions on a dial only 20mm dia. Each division would be 0.6mm (approx) apart a bit too close, you might manage 50 divisions though which is a nice round number.
                Posted by Steven Woodward on 10/05/2021 14:29:34:
                You might find this useful in your assessment of that, Steven : **LINK**
                https://shop.mitutoyo.co.uk/web/mitutoyo/en_GB/mitutoyo/Quick%20Spindle%20Feed%20Micrometer%20Head/Micrometer%20Head%20Quick%20Spindle%2C%201mm-rev./$catalogue/mitutoyoData/PR/152-101/index.xhtml
                Mitutoyo seems to have chosen the thimble diameter wisely
                Journeyman
                  @journeyman
                  This from ** Arc ** might be of use
                  swood1
                    @swood1
                    There are some useful responses here, thanks.
                    I didnt think of the mircometer dial, just wondering if I could buy some 2nd hand ones and modify them.
                    Steve
                    #544371
                    swood1
                      @swood1
                      Posted by Journeyman on 10/05/2021 14:36:30:
                      John,
                      I think I am going to take your advice above and make my own.
                      Thanks all
                      Steve
                      #544473
                      Bazyle
                        @bazyle
                        Can you accomodate any larger? Boxford dials are about an inch, and some of the old SouthBend lahtes are smaller. Old Myfords use a small anngled one with cast raised numbers and marks which are listed on spares sites but I think I've seen elsewhere are not in stock anywhere.
                        Another search method is to put selections of suitable words into Google image search and see if the results take your fancy, then try to identify them.
                        #544500
                        swood1
                          @swood1
                          Yes I could,
                          Looking at the design today, I believe I can accomodate a 34mm diameter dial.
                          I shall have a look at your suggestions. Thanks
                          Steven
