Small dia end mills
Small dia end mills
Home › Forums › Beginners questions › Small dia end mills
  • #306794
    Alfie Peacock
      @alfiepeacock58331
      I have some small dia end mills up to 6mm with a hole in the middle, what are they used for. If they were slot drills or the three edged cutters they are used for slots etc, but these end mills cant be used for this. A stupid question this must seem to experienced model makers, but if I'm milling a edge I would use a larger dia for rigidity.
      #8786
      Alfie Peacock
        @alfiepeacock58331
        #306799
        Thor 🇳🇴
          @thor
          Hi Alfie,
          May be this thread explains?
          If I don't have a slot drill matching the slot width I want to cut, I start with an undersize slot drill and then uses an end mill to widen the slot to the correct dimension. For a narrow slot you would need an end mill with a diameter slightly less than the width of the slot.
          Thor
          #306821
            Any chance of a photo? I wonder if they might be counterbores rather than end-mills?
            Chris Evans 6
              @chrisevans6
              If the hole goes all the way through they may be for a CNC machine with through spindle coolant.
              #306880
              richardandtracy
                @richardandtracy
                If there is one with a 1.5mm hole & 7mm OD, I want to know where to get them… I've come close to having end mills spark eroded to make them like that.
                Richard.
                #307032
                John Reese
                  @johnreese12848
                  I have some non center cutting end mills that have a small recess in the end. They can be used to cut blind keyways or slots if the mill is gradually ramped down to full depth. It is not ideal, but it works.
