slow speed attachment for Unimat SL
Home Forums Workshop Tools and Tooling slow speed attachment for Unimat SL
Viewing 21 posts - 1 through 21 (of 21 total)
  • #68798
    David Costello
      @davidcostello75947
      Where can i buy this attachment DB1280 in the Uk?
      David Costello
        @davidcostello75947
        #68799
          Probably have to resort to US e-bay and a seller that will do deal to UK then get hit for import duty & VAT
          For the same sort of money you could get a vari speed motor, not sure what teh slowest speed is but worth asking here
          Jason
          Edited By JasonB on 18/05/2011 19:17:22
          #68803
          David Costello
            @davidcostello75947
            Thanks Jason,but not at that price.yes ebay has a US seller but again a bit steep.I need to turn some 50mm od steel which the book tells me 350rpm,my slowest is 900rpm,so will try that first.
            Dave.
            #68804
              Didn’t realise the slowest speed was that high, thought it would be about the same as my old Unimat 3.
              You may just get away with very fine cuts, hope you have not got too much metal to remove.
              J
              Edited By JasonB on 18/05/2011 19:45:48
              #68805
              Martin W
                @martinw
                David
                Any merit in trying an electronic speed controller similar to that used in mains operated drills etc. There will be a certain loss of power but it may do at a pinch with very light cuts.
                Cheers
                Martin
                Try Maplin they may have a unit/kit.
                #68806
                David Costello
                  @davidcostello75947
                  Thanks Martin
                  Yes could be an option,will have a think on that.
                  Roderick Jenkins
                    @roderickjenkins93242
                    David,
                    Your book speed of 350rpm for 2″ (50mm) gives a surface speed of about of about 180 ft/min. Your lowest speed of 900rpm gives a surface speed of about 470fpm. The tables in Machinery’s Handbook (admittedly as a guide for production) give a speed of 150fpm for HSS on plain carbon steel but for coated carbide the recommended speeds are between 400 and 800 fpm. You should be able to get away with a sharp coated QC tip, though the swarf could well be coming off blue and smoking, depending on the feed. I appreciate that the your motor power is limited but I reckon it is worth a try.
                    Rod
                    #68811
                    dcosta
                      @dcosta
                      Hello David!
                      I have with me a number of accessories (never used) for small Emco machines.
                      My first lathe (1982) was an Emco Unimat 3 and at that time I bought two small boxes with accessories from a closing shop. Though some of the accessories were usable in my Unimat 3, most of them were for an older Unimat (I think Unimat SL) I could use some of them in Unimat 3 (e.g.: the 3 jaw chuck, the 4 jaw chuck, the faceplate, a drill chuck, the fixed steady, etc.).
                      Among the items I have, there are two DB202-21 (Motor bracket). Comparing it with the one originally proposed for speed reduction, it looks to me it will be a non dificult operation to add support for another pair of wheels…
                      Follows the URL for  the Double speed reduction picture.
                      and for the Motor bracket
                      To benefit the comparison I horizontally rotated the second image.
                      Good luck with Your endeavour
                      Dias Costa
                      Edited By Dias Costa on 18/05/2011 21:41:54
                      #68818
                      ady
                        @ady
                        The original motor power is extremely limited on the wee unimat sl, belting is a big big issue as well. The motor usually needs resting every 10 minutes or so to prevent overheating.
                        (going back a bitty now)
                        I ended up removing the original motor and getting a 1450rpm off ebay, then getting some of that 4mm red belting and fixing the lot to a baseboard.
                        The difference was like night and day for lathe work, she actually made hot swarf!
                        The original motor was still needed for the drilling configuration though.
                        They are pretty amazing little units and highly versatile but quite limited for serious work because they really do lack stiffness, especially when that little weeny carriage is hanging out over thin air for a side cut, too much flexing.
                        If the ways/bars had been 16mm instead of 12mm this would have made a huge difference.
                        Watchmakers use units like Cowells lathes, which have a ‘proper’ bed and even have backgear.
                        If you do continue down the slow speed attachment route invest in some decent belting to transmit as much power as possible to the spindle for a decent cut.
                        Without decent belting you can’t do much work on a unimat sl.
                        #68832
                        Ian S C
                          @iansc
                          You could use an old 1/4 hp 1450rpm motor, I don’t know about your side of the world, but here you would pay about $NZ20 for a good one, and with the right pullies, and a counter shaft, you can have what ever speed you want. You could hang the motor under the bench top,and bring the belt up to the counter shaft on top. The heat fused belting is a good way to go, I use it on my Super Adept, 5 mm I think. Ian S C
                          #68835
                          Richard Parsons
                            @richardparsons61721
                            David,
                            I bought my Unimat SL in the mid-60’s. I still use it (with its original motor). They are nice little machines if used within their limitations.
                            One of the strength (and weaknesses) is the motor. The original motor is what I know of is a ‘universal motor’. It has brush gear and can run on either AC or DC. This being the case it can run on ‘pulsed DC’. A pulsed DC speed controller provides a 230 volt DC pulse and controls the motor speed by the length and frequency of the pulses.
                            I bought my speed controller kit about the same time as the Unimat. It is still working and is used to control the Russian spin drier motor which drives my tool grinder. I have had a look see on Google and have found this at http://www.quasarelectronics.com/smart-kit/1074-ac-motor-speed-controller-230vac.htm (usual disclaimer). But there are loads of circuits to choose from.
                            Your motor is 100 watt I would go for the 350 watt unit. (it is more complex than mine but seems to have a speed range of 5% to 95% of full speed output).
                            These units can have problems at low speed where high torque is required. I had a mill which at low speed caused ‘surging’ when taking anything but the lightest of cuts.
                            Dick
                            Edited By Richard Parsons on 19/05/2011 07:15:32
                            #68853
                            Ian S C
                              @iansc
                              To get low speed its always better to keep the revs up and use mechanical speed reduction, electric motors do not like low speeds, the fan for cooling becomes innafective. A bigger motor would be a help. Ian S C
                              #68854
                              CJW
                                @cjw
                                David,
                                I thought the lowest speed on a Unimat SL with the standard UK motor and speed reduction was 365 rpm. Do you have a different setup?
                                Chris
                                #68857
                                David Clark 13
                                  @davidclark13
                                  Hi There
                                  There was an attachment available that added another pulley to the Unimat SL to give a lower speed.
                                  regards David
                                  #68858
                                  CJW
                                    @cjw
                                    Hi,
                                    I found this which has details of the speeds with standard pulley and motor combinations.
                                    All the best,
                                    Chris
                                    #68861
                                      David the attachment you mention is the DB 1280 that Davy is asking about.
                                      Lathes.co.uk give speeds of 900 to a rather hair raising 7200!! on a MK 1A machine.
                                      Jason
                                      #68863
                                      Richard Parsons
                                        Ian SC From memory The Unimat SL motor has a vestigial fan. When I used it as a work centre I had a little battery driven fan which allowed me to run for more than the 10 minutes described in the book.
                                        Dick
                                        #69200
                                        David Costello
                                          @davidcostello75947
                                          Update to my original post.
                                          50mm steel turns ok at 900rpm,no problem as envisaged.
                                          Dave.
                                          #69201
                                            That will be the plough wheels made then
                                            #69203
                                            David Costello
                                              @davidcostello75947
                                              A start on one Jason
