I bought an arbour at the Midlands exhibition & have been given a handful of 3mm saws. I went to use one today & was surprised that it would cut nothing.
The blade is 80mm diameter, 3mm th, & tooth pitch is 8.5mm point to point.
I wanted to form a tongue in the end of a piece of 9.5mm diam chromed steel shaft taken from a photo copier that I am using for the piston in a hand feed water pump for my traction engine. (where it joins a slot in the handle)
If I ran the cutter slow ie 100RPM it just bounced off the steel & as I increased speed to 650 RPM it just created sparks
Can someone advise me on the correct RPM for a saw of this diameter & tooth pitch please. I have several so will try others although this one seemed really sharp at first- It is HSS.
I have not tried a milling cutter yet but it may be that the steel is very hard but i think not as it seemed soft in the middle when I cut it to length. It is just that I thought that i would try it out the saw as i could clamp the rod horizontally, take a slice of the top, drop the cutter down & take a slice of the bottom & leave the tongue in the middle nice & parallel
Edited By Sam Longley 1 on 24/10/2017 21:19:57
