Single phase verses 3 phase motor
Home Forums General Questions Single phase verses 3 phase motor
  • #26431
    Philip Slater
      @philipslater86297
      Philip Slater
        @philipslater86297
        Hi all
        Not sure if this is a good place to direct this question or not but here goes.
        I'm fairly new to model engineering and am in the process of building up a Tom Senior M1 milling machine to which I've grafted a Rambaudi vertical head. I now need to fit a motor to the vertical head and was looking at fitting a 1 1/2 HP type. I was going to go for a 3 phase motor with a VFD but it occured to me I could make the job a bit cheaper and fit a single phase motor.
        Does anybody have any thoughts on this? I would think the 3 phase motor would be smoother running and I like the idea of a soft start but I can save the cost of a VFD if I go single phase.
        #395464
        Gary Wooding
          @garywooding25363
          I fitted VFDs to my Centec – smooth start and variable speed is far better than 1-phase.
          #395466
          Brian Oldford
            @brianoldford70365
            IMHO good solid 3 phase motors of that capacity can often be picked up S/U for a song. With all the advantages of Soft Start, Infinitely Variable Speed and even Over-speed a VFD is a no-brainer.
            I have them fitted to both my mill and lathe and wouldn't go back to single phase machines.
            #395473
            duncan webster 1
              @duncanwebster1
              Wouldn't go back to single phase for all the tea in China. 1.5 HP single phase is going to be quite a lump as well, as Brian says you'll get S/H 3 phase if you search. Try Gavin Oseman who sometimes advertises on **LINK**. Never dealt with him but I know a man who has.
              #395477
              Pete White
                @petewhite15172
                Double post, instead of edit, as below.smileyangry
                Edited By Pete White on 09/02/2019 18:27:47
                #395478
                Pete White
                  @petewhite15172
                  I am lucky to have 3 phase in the workshop, never used a VDF, but do you need to ensure your motor is a six ends out so that you can make sure the voltage is correct, or already suitably wired?
                  There was single phase motor on my wood lathe when I bought it., it was hopeless with all the stopping and starting leading to over heating. Sorted by fitting a readily available cheap three phase option. Maybe the motor had a problem but convinced me that single phase is not for me.
                  Pete
                  #395481
                  Mike Poole
                    @mikepoole82104
                    I would not hesitate to go with the three phase solution. Three phase motors do run more smoothly and the flexibility of the variable speed is sure to be found useful, in my opinion running a VFD at the extremes of its range is to be avoided as this compromises motor performance but it will still save a lot of belt changes and it is easy to find the best speed for the cutter and material being used. Even if I had a three phase supply I would still like a VFD as it enhances the usability of a machine.
                    #395490
                    Philip Slater
                      @philipslater86297
                      Preety conclusive then!! I hadn't thought of running the VFD beyond 50hz but as suggested you would have to be a bit careful doing this. VFD and 3 phase motor here I come then.
                      Thanks for the rapid respones
                      #395509
                      Brian Oldford
                        @brianoldford70365
                        Posted by Pete White on 09/02/2019 18:26:22:
                        Pete
                        Actually Pete, so long as the stator windings aren't epoxy potted, on a three post machine (415v only), if you're not afraid of a bit of motor open heart surgery, you can almost always get to the star point and open it up. Carefully noting the phase relationship you can rewire it to delta and they'll invariably run beautifully. Getting the phase relationship is crucial (don't ask!).
                        #395513
                        Hollowpoint
                          @hollowpoint
                          Looks like you have already made your mind up but here's another vote for 3 phase. I converted my boxford a while back and it runs so much better now! yes
                          #395569
                          Pete White
                            @petewhite15172
                            Posted by Brian Oldford on 09/02/2019 21:26:07:
                            Thanks for that Brian, I have never stripped a motor but thought the star point would be like looking for hens teeth. I might have have a go. I am not afraid, I used to run motors and a mig welder, form an oil cooled welder and very big capacitors capacitors years ago. I think I am to afraid these days to do that again. lol
                            Pere
                            #395580
                            Sandgrounder
                              @sandgrounder
                              Posted by Brian Oldford on 09/02/2019 17:17:30:
                              The same here, also fitted one to my Meddings Pillar drill which makes things so much easier when countersinking a hole after drilling, I don't have unscrew the pulley guard, loosen the motor, move the belt, c'sink the hole, loosen the moter, move the belt, lever it back to tension the belt and replace the guard.
                              #395623
                              Ian McVickers
                                @ianmcvickers56553
                                Yes vfd and 3 phase motor all the way. Some wiring and a few buttons and switches and you can choose from fwd/rev. High/mid/low speed or fit a pot and vary the speed to your hearts content.
