Simplex Superheater Details
Home › Forums › Locomotives › Simplex Superheater Details
  • #298141
    Martin Johnson 1
      @martinjohnson1
      I am doing calculations on several Loco designs to determine the amount of superheat. I know the Simplex has a single superheater flue 1.125" OD, but I don't know what the drawings show to go in it. I guess it would take 4 passes of superheater tube? What diameter? Maybe a Schmidt type arrangement? Or 2 parallel out and back pipes – one for each cylinder perhaps? Is a radiant arrangement intended?
      Description and major dimensions would be greatly appreciated.
      Thanks in advance,
      Martin
      #1606
      Martin Johnson 1
        @martinjohnson1
        Plea for dimensions
        #298144
        Clive Brown 1
          @clivebrown1
          My drawing shows a 2 element radiant superheater, 7/16 inch dia. stainless tubes extending to the back of the firebox.
          #298145
          John Baguley
            @johnbaguley78655
            Hi Martin,
            the superheater is a single out and back made from 7/16" x 20g stainless tube. It is a fully radiant type extending right to the back of the firebox.
            Martin Johnson 1
              @martinjohnson1
              Thanks for that John – ultra quick on the reply too!
              It's no surprise that there seem to be quite a few alternative superheater layouts for Simplex then!
              Many thanks,
              Martin
            Home › Forums › Locomotives › Topics
