SIMPLEX DIMENSIONS
SIMPLEX DIMENSIONS
Home › Forums › Locomotives › SIMPLEX DIMENSIONS
  • #1492
    Martin Johnson 1
      @martinjohnson1
      Help Needed
      #224145
      Martin Johnson 1
        @martinjohnson1
        Hello
        I am currently analysing past IMLEC results to try and improve the thermal design methods for small boilers. Please can anyone help with the following dimensions of the Martin Evans “Simplex” design:
        Cyliner bore
        Cylinder stroke
        Wheel diameter
        Grate length
        Grate width
        Firebox height
        Firehole diameter
        Smoketube diameter and number
        Superheater flue diameter and number
        Length of tubes
        Working pressure psi
        Safety valve bore
        Many thanks in advance
        Martin
        #224161
        Trev67
          @trev67
          Hi Martin
          Bore: 11/2"
          Stroke: 2 1/8"
          wheels: 4 3/8" on the tread
          Grate length: 5 5/8" ( distance between firebox plates)
          Grate Width: 2 3/4"
          Firebox Height 5 3/4" at the front, 4 5/8" at the back ( these are the dimensions of the plates, the grate sits inside slightly, reducing these a little)
          Firehole : 1 1/2"
          tubes: 13 x 7/16 20swg
          Superheater flue: 1 x 1 1/8" 16swg
          Tube length: 11 3/162
          working pressure: on the drawing 110psi , (but I don't know if people run them this high?)
          Safety valve: 2 x 3/16" bore
          Hope this helps
          Trevor
          #224229
          Martin Johnson 1
            @martinjohnson1
            Trevor,
            That is absolutely brilliant. Thank you very much.
            Martin
          Home › Forums › Locomotives › Topics
