Simple Mill Engine
Simple Mill Engine
Home › Forums › Drawing Errors and Corrections › Simple Mill Engine
  • #135428
    Eric Cox
      @ericcox50497
      Potential error on the bill of material.
      Are the slide bars, MP15, 4 x 12" long or 4 x 3" long
      #38779
      Eric Cox
        @ericcox50497
        #135431
        Stewart Hart
          @stewarthart90345
          Hi Eric
          They are 4*3" long so you will require 12" :- sorry if I got it wrong blush
          Stew
          #135451
          roy entwistle
            @royentwistle24699
            Stewart Sorry to be pedantic but if you require 4 x 3" surely you need more than 12 inches unless your hacksaw blade is thinner than mine
            Roy
            #135454
            Stewart Hart
              @stewarthart90345
              Roy
              3" is over 75mm the finished slide bars are 68mm long so you have over 7mm to play with for each bar if you buy a 12" length of 1/4" sq bar you will have plenty of material to make all four slide bars.
              The quantity of material on the bill of material has been calculated to allow for manufacture:- chucking/facing etc
              Stew
