Sievert Pro86 adaptor to nozzle 294102
Home › Forums › General Questions › Sievert Pro86 adaptor to nozzle 294102
  • #716391
    Grizzly bear
      @grizzlybear
      Hi Everyone,
      I recently purchased the Pro86 torch with the needle flame kit, plus a burner 294.
      With help from the forum, thank you.
      What do I require to connect the 294102 to the torch?
      I’ve studied the parts list, is the item below the right part?
      Sievert Pro 86/88 Short Neck Tube 70mm + Hook – Gas Torch Accesso (tradecounterdirect.com)
      PRMS 3511 Part number.
      Bear……….
      #716394
      Diogenes
        @diogenes
        Er, yes, about 99% sure that that is correct (I don’t have the original invoices to hand) – I know a few others here have them, maybe someone else will confirm.
        If you don’t get confirmation by tomorrow morning I’ll go and check the torch itself, it’s elsewhere at the moment.
        #716409
        Grizzly bear
          @grizzlybear
          Thank you, I’m almost convinced it’s the correct one.
          #716452
          Diogenes
            @diogenes
            I’ve just found the information at Sievert;
            So the answer is yes, Necktube 3511 will connect Burner 2941 to the 3486 Handle – Sievert sell this set-up as one of their ‘Pro 86 Torch’ kits.
            ..it’s a good G/P set up with enough sensitivity and flame stability to be used surprisingly softly for smaller work, with a generous output available at full chat – I rarely change the burner on mine..
            https://sievert.se/wp-content/uploads/2017/01/Sievert-Pro-86_ENG.pdf
            #716533
            Grizzly bear
              @grizzlybear
              @Diogenes,
              Thank you, I do appreciate your help and advice.
              Bear……
